Speed Passion Thread >
Like Tree4Likes
Old 03-16-2013 | 10:30 AM
  #3436
Originally Posted by FastPete
Thank you, do u think it would be ok for a heavier truck like the Tekno?
In your opinion is it worth switching from a RX8? I happy with the RX8, but always looking to improve.
Not sure about a Tekno... Those things are heavy. I like the SP because I don't need to lug around a laptop
kerby is offline
Old 03-16-2013 | 01:29 PM
  #3437
I tried running the Rev Pro in my Tekno SCT410 and no worky. I was running stock 0 software with a HW 4000kv 4-pole. The motor never got above 130 but the ESC would hit overheat protection in less than 3 minutes of normal driving. I turned off overheat protection, drove like a granny and the ESC would completely shutoff after 5-8 minutes.
SP guys, any idea why the Rev Pro cannot handle a 4-pole in an SC running stock 0 software? The GT 2.0 which is 120a seems to have no problems, but the Rev Pro which is 140a cannot hack it.
AlderBoy is offline
Old 03-16-2013 | 01:47 PM
  #3438
FastPete's Avatar
Im not running a 4 pole. A trinity 5.5 550 can. Do u think at may work then?
FastPete is offline
Old 03-16-2013 | 01:56 PM
  #3439
No idea. The SP guys previously said it could handle a 4-pole and I couldn't make that work. A 550 draws less Amps, so perhaps. Until the SP guys jump on here and explain what is going on I would go with the GT 2.0 or a dedicated SCT ESC.
AlderBoy is offline
Old 03-16-2013 | 02:11 PM
  #3440
FastPete's Avatar
I hear you. Seems hard to get a straight answer. Maybe need to call a tech at SP this week.
I want to use SP stuff in my on road stuff this year. And wondering if its worth changing from my RX8 in my 4x4sc, to something SP like a GT2.0 or Revention Pro. If no one has a AB comparision I may just stay with the RX8 in the truck.
FastPete is offline
Old 03-16-2013 | 05:17 PM
  #3441
makaluch's Avatar
Originally Posted by MOmo
Strange.
Totally random, what is your radio setting? I noticed that if I had anything other than a linear curve, it would also do strange things when i ran the GT 2.0 or LPF ESC. Waiting for a car to show up on Mon before I test the new REV S. in it.
MOmo
Radio is linear. I don't use exp. I found with the Tekin RS Pro if I roll on through the apex that it would slide out just before straightening the front wheels. I tried tightening the diff a bit and different lines, tuning roll center, backing down the can timing, and gearing up ... with no joy. I'm hoping the Reventon Pro is as smooth as I'm hearing.
Any stock setting or tuning tips would be appreciated.
makaluch is offline
Old 03-16-2013 | 05:46 PM
  #3442
I just reviewed the Tekno specs. It is basically a 1/8 and super heavy. I wouldn't trust any 1/10 esc in that thing.
kerby is offline
Old 03-16-2013 | 05:51 PM
  #3443
sugs's Avatar
Originally Posted by PastaBoyNY
First trophy race in a dozen years. This ESC was flawless!
After a rough start (lost equipment that showed up next day and blown idler gear) I managed a 2nd Plc c-main Finnish and 5th in the B. wasn't too far off pace with a new layout and all the difficulties of the day.
Solara, thank you for the clarification that my settings work well.
It's my pleasure to provide input! Great product and support.
The pro4 will work in Mod2 settings. Just NO boost.. Ever!
Don't need on these motors anyway!!
Have fun gents!
Sal
Just take a look back at the settings I'm running in MOD 2 and do not use boost of any type.
Sal
This was discussed a while back, I'd send a pm to PastaBoyNY whom I quoted for you or Cain for suggestions on settings. It sounds like you need to change to mod 2 software and make sure you are running NO BOOST, and I think no timing either, but they would know for sure.
sugs is offline
Old 03-16-2013 | 05:59 PM
  #3444
FastPete's Avatar
Well thanks for looking into it.
FastPete is offline
Old 03-17-2013 | 11:10 AM
  #3445
Cain's Avatar
Tech Legend
I am running no boost or timing with the SP GT2.0 Pro. Based on the discussions had, the Reventon Pro should be able to do the same with no timing, boost, etc. The problems originally reported were when they were testing the ESC with all that stuff which we don't use in 4x4 SCT.
a blink or mod software is what I personally would use if I was running the Reventon Pro and a 4 pole motor.
I run the SP GT2.0 Pro in my Tekno SCT410 with a Tekin Pro4 4600Kv motor and it works excellent. I am using the latest MOD software, no boost, timing, etc.
I have also heard that you can use the Silver Arrow V2 ESCs on 2S which, considering the guts of it look similar to the hobbywing or whatever stuff which does work on 2S, don't see why not. There are even settings in the software to set it as such.
Cain is offline
Old 03-17-2013 | 11:29 AM
  #3446
07Forester's Avatar
I run a reventon pro and a prototype 550 can 2 pole motor in my 4x4 sct and it works flawless. There are also drivers running reventon pros in tekno trucks with great success as well.
07Forester is offline
Old 03-17-2013 | 11:30 AM
  #3447
Cain's Avatar
Tech Legend
what are the rotor sizes of the new Blaze 550s?
Cain is offline
Old 03-17-2013 | 06:46 PM
  #3448
I looked at PastaBoyNY posts and any of the software options that don't have boost should work. I have been running stock 0 which has no boost or timing and it still doesn't work. So something is wrong.
AlderBoy is offline
Old 03-17-2013 | 09:29 PM
  #3449
Waflet's Avatar
Hideeho
Finished testing my new reventon r & lrp motor. I ended up trying a friends reedy & it ran the whole pack with no problem. That eliminated the ESC as the source of the problem. Then I swapped the lrp from my b4 to my b44 & vice versa. The b44 (with an RS pro ESC) ran perfectly. Then I ran my other lrp in the b4 (w/ the rev r). Not a single problem all the way to lipo cut off, & smooth as a babies bottom to boot!
The problem turns out to have been with that 1 individual lrp motor. Swapping the 2 8.5t solved the whole problem. I'll just have to remember if I end up getting a rev pro for the b44 I'll also need a different motor for it.
Now I get to start playing with the timing in the ESC in preparation for next Saturdays $ race!
Waflet is offline
Old 03-17-2013 | 10:20 PM
  #3450
sugs's Avatar
Can't hurt to try mod 2 and see if it makes a difference. I believe the official stance from Speed Passion is the Reventon Pro doesn't support 4 pole motors, even though at least some people have done it with success.
sugs is offline
