Speed Passion Thread >
Like Tree4Likes
Old 06-03-2014 | 10:59 AM
  #4891
Originally Posted by the incubus
You want a 30mm fan on the Reventon Pro, not the 25. The most durable fans I've used are the MuchMore Racing Fans. The absolute worst are the scorpion fans. Utter junk.
NEXUS: Any guesstimate when the V4 motors will be in stock, and if so where?
I need a 17.5 for my new 2WD buggy and was eating towards the MMM but wight he V4's now, I think I'd rather have that.
I believe the Modified V4s will arrive first then later the "stock" winds. Early indication was end of June, but I will verify that later.
Nexus is offline
Old 06-03-2014 | 11:04 AM
  #4892
the incubus's Avatar
Excellent thanks!
Either way my new kit arrives Friday and I'm still 2-3 month away from being able to stand on my own again and have plenty of time to wait for them to be released, though I'll likely just install my spare 8.5 just to give it a few test/setup runs out back.
Hell, I even have enough time to send my parts out for custom ano.
the incubus is offline
Old 06-03-2014 | 12:12 PM
  #4893
Cain's Avatar
Tech Legend
so these V4 motors, what rotor size do they come with, 12.3 or 12.5?
Cain is offline
Old 06-04-2014 | 10:17 AM
  #4894
13Maschine's Avatar
Original Reventon Pro 1.0 units (not 1.1) are 25mm fans. Not 30mm. I think this might work to use 30mm fans:
http://www.ebay.com/itm/140898549624
Speed Passion has a V4.0 motor coming? Anyone have links to info?
13Maschine is offline
Old 06-04-2014 | 10:18 AM
  #4895
Nexus is offline
Old 06-04-2014 | 10:23 AM
  #4896
13Maschine's Avatar
Here's some info: http://www.redrc.net/2014/05/speed-passion-competition-v4-0-brushless-motor/
I WANT ONE!
Old 06-04-2014 | 10:27 AM
  #4897
Old 06-05-2014 | 02:29 AM
  #4898
13Maschine's Avatar
Nexus = Albert Mui?, Do you represent Speed Passion officially?
Old 06-06-2014 | 11:23 AM
  #4899
I heard Albert is much shorter yes.
Nexus is offline
Old 06-08-2014 | 11:55 AM
  #4900
TXDSkinGraphix's Avatar
Default on/off button issues???
Has anyone had any issues turning off their Reventon Pro's. I've had it happen twice recently. Hold down on the button and nothing is happening. Its offroad so COULD be a dirt issue and contact, but if that's the case turning on would be an issue as well. Thx everyone!!!
In regard to the 4.0 motors. Last correspondence I received stated late June early July for release. And YES... the will be dope!
TXDSkinGraphix is offline
Old 06-08-2014 | 12:35 PM
  #4901
13Maschine's Avatar
I've run into this a few times. I usually just pull the battery plug…what Version do you have? Sometimes it seems that I'm not holding it down long enough….
Old 06-08-2014 | 12:40 PM
  #4902
Both times this has ben on my 1.0 pro. first time it happened couldn't get it to come back on... so got a bit concerned. Ivenot held down long enough as well many times...... but this time the red light didn't even blink. Probably need to throw my 1.1s in.... was trying to wear out the 'old blues' first. Guess its time.
Old 06-08-2014 | 01:17 PM
  #4903
Try blasting your ESC with a few bursts of compressed air to flush out any dirt that may be hindering full depression of the button.
Old 06-08-2014 | 02:42 PM
  #4904
BigRon's Avatar
Are there any lights on while your trying to turn it off? Sometimes (for some odd reason) it goes into a standby mode after a short period of no activity. I just apply the brakes then push and hold the button to turn it off.
BigRon is offline
Old 06-08-2014 | 03:04 PM
  #4905
ya know that very well could be it as well. Def try it and giving it a blast of air. Thx Team!!
