Speed Passion Thread >
Like Tree4Likes
Old 04-01-2014 | 11:59 AM
  #4741
Jack302's Avatar
Questions??
I just got a reventon pro 1.1 can i please get some free SP Decals?
Jack302 is offline
Old 04-01-2014 | 12:31 PM
  #4742
Captcha's Avatar
Originally Posted by Captcha
I have a Tech question of sorts. I am looking at getting the Reventon Pro 1.1EX very soon, and with my stock car (17.5 2wd buggy) I run both stock and mod, so I want an ESC that I can add boost and such for the mod class. My question is, can this be down with the LED or LCD card, or only through the Computer Program? I believe a friend has a reventon pro, and stated he can only change his on the computer. This does not effect me at all, I am just curious so I know.
Thank you in advance,
Brandon
Spoke to a representative for Speed Passion, and he confirmed you need a computer/laptop to switch timing profiles. OR A wifi card and the app.
Captcha is offline
Old 04-03-2014 | 12:07 PM
  #4743
Default Reventon R
Hi Guys,
I just bought a Reventon R with a V3 9.5 motor for my son's Losi 22T.
Installed everything and it's running well but I have a few questions.
When I plugged to the computer with the led card, it had Mod0 loaded on the esc but the manual states that Mod1 is the default firmware? Are some shipped with MOd0 as default?
Which firmware would be best for offroad track? Been reading the entire thread but it's hard to figure out the difference between the firmware. Stock vs mod... etc.
I geared it 80-20. So far not that impressed with power\speed but temps are low so might gear it up. What's a good gearing for 9.5 in this Losi 22T?
Appreciate the help.
Steve47 is offline
Old 04-03-2014 | 05:48 PM
  #4744
Hey guys I picked up a Reventon S ESC and the manual says it can work with a motor down to 9.5T... So I was thinking of grabbing one of these from Hobbyking:
http://www.hobbyking.com/hobbyking/s...dproduct=21957
But that motor lists a max current of 47A where as the manual says the ESC is only rated for 40A Continuous? So will they work together comfortably or would I be pushing my luck? Thanks!
norco kid is offline
Old 04-03-2014 | 05:58 PM
  #4745
caprezmikeb's Avatar
I'm doing the same thing. But with two cars(b5 and b5m). So I bought two of the pro 1.1. I was told with the pro box which is the LCD box that I can add boost.
caprezmikeb is offline
Old 04-03-2014 | 06:28 PM
  #4746
Originally Posted by S.TRIPP77
OK guys I am boosting a 17.5 with the stock 1 program and the question is???? Is the slop rate how fast the motor spins down from full trigger??
Does anyone have answer to this?? Please?? I will be ur best friend?????
S.TRIPP77 is offline
Old 04-04-2014 | 10:22 AM
  #4747
With the box you can adjust boost assuming you have the correct software loaded on the ESC that allows boost adjustments. But what he is saying is switching the software on the ESC from a boosted or "Mod" software to a Blinky software. That cannot be done without a computer. Or apparently it can also be done with the wifi module and the app on your mobile device. But it cannot be done with the just the LCD/LED box.
RedDevil13 is offline
Old 04-05-2014 | 08:18 AM
  #4748
Is there any place to buy the plastic bottom case? My broke at the screws and would like to put another one on to protect the electronics. I looked on speedpassion website but there are no accessories to purchase a new case.
tfrankito is offline
Old 04-05-2014 | 09:01 AM
  #4749
Kremzeek's Avatar
Which ESC? You can get replacement bottoms for the Reventon Pro at http://shop.speedpowerrc.com/
Kremzeek is offline
Old 04-05-2014 | 09:38 AM
  #4750
reventon pro 1.1.
Old 04-10-2014 | 08:53 PM
  #4751
mocrawlin's Avatar
Hey guys. I picked up a truck that came with a citric stock spec speedo and 13.5 combo. I would like to run this in one of my b4 biggies in either 13.5 or 17.5 class. But, when I tried to run it with the 13.5 it ran fine for a couple minutes or so and the slows. I keen wheel just spin slowly when picked up off ground at full throttle. I down loaded the manual, but it lists all the other speedos with it and is very confusing and vague in the setup part. I was told it was probably the lipo cutoff setting or temp setting. But o don't have a clue how to change either. I can get it into setup where it does the beep--beep, but what does it keen and what do I do to get to the next setting? LoL is anyone familiar with it? Can help me thru this?
mocrawlin is offline
Old 04-11-2014 | 10:51 AM
  #4752
reventon pro 1.1.
http://shop.speedpowerrc.com/reventon-series/
All Reventons have the same lower case.
Make sure you recalibrate your transmitter to the ESC. Are you sure you downloaded the Cirtix Stock Club manual? It's an older ESC and the manual was only for that version.
http://www.speedpassion.net/uploadfi...pt09rd2010.pdf
Nexus is offline
Old 04-11-2014 | 02:48 PM
  #4753
HeavyD99 is offline
Old 04-11-2014 | 03:03 PM
  #4754
Pittsdriver's Avatar
Just heard back from SP regarding the iOS app upgrade. They are saying summer of 2014.
Pittsdriver is offline
Old 04-11-2014 | 06:29 PM
  #4755
RichyRich's Avatar
Default Blaze 5700
Has anybody run the Blaze SC 5700kv?
It seems a little sluggish with not a lot of rip to it. I boosted timing up slightly about 6 deg and it seemed to help but not sure how much timing is in the motor or how much I can go. I thought the 5700 would be more than plenty but it does not have nearly as much rip or punch as my Tekin 4300.
Any help would be appreciated.
RichyRich is offline
