Speed Passion Thread
#4876
More CAPS wouldn't really help in most situations. I don't there's a point of diminishing returns, but more caps isn't necessarily better or needed. If that was the case we'd see tons more caps in modified classes.
#4877
What's a good 25mm replacement fan for the Reventon PRO 1.0 Units? The newer model uses a better fan but I haven't upgraded yet and I've killed a couple of the speed passion fans really easily. Thanks!
#4878
Use a Reventon R with a 7.5T in a SC10.2 and very happy with its performance. I'm wondering what the differences are between the three setups. I'm using Mod 0 . Will be switching all my cars to SP. Love the pricing and the reliability
Thanks,
Rich
Thanks,
Rich
#4879
Also I have a really narrow neutral range. As soon as I pull the trigger there is no hesitation. I mean I can pull it a fraction of an inch and it starts the motor. It also happens in reverse, if I'm using reverse during practice. Again using the Reventon R speed control. Can this be control from the ESC or better to use my Futaba Radio to control this?
Thanks,
Rich
Thanks,
Rich
#4880
Modify 0 on a Reventon R & Competition v3.0 here too.
That's a great set-up - impressively smooth operation and lots of power under the hood.
One question if I may: it takes some time and 5-6 presses on the throttle until I can activate the reverse... is this related to the motor having to come to a full stop before it starts rotating backwards?
I mean is this normal or should I do something?
#4883
mod 0, mod 1 and mod 2 are each a little smoother than previous. if you are running mod 0 and liking it you will probably find that you like the others even more. mod 0 has a point in the throttle that you can kind of feel it kick in. that makes it harder to control on anything but high bite. mod 1 and then mod 2 have less of this effect.
if you want less throttle response you can try a higher percent on the narrow band or use a little negative exponential. (If you use a Spektrum radio you would use a positive number on the expo function. )
#4884
Thanks,
Rich
Thanks,
Rich
Recalibrate your TX to the ESC. Make sure your nuetral, full throttle and full brake are set correctly.
http://www.speedpassion.net/us/catagory.asp?c=mtr&sc=56
I know that a few of our sponsored guys have run low turn 540 mods in 4x4 SCT with success as well.
#4885
#4886
[QUOTE=Nexus;13290379]Rich,
Done that a couple of times with the same results. It's not a really big deal but if I accidentally hit the trigger its off and running!!! I even set the ESC to 12% on the Neutral Range Setting. Starting to wonder if in the neutral radio calibration if I moved it a few degress back and forth would it pick that up and register it???? Not sure just thinking of ways to make it work.........
Rich
Rich
#4887
#4889
Braking is fine. Strong and immediate. The problem is it takes some time for the system to engage the reverse...
I did recalibrate the ESC and it's still the same behaviour.
#4890
NEXUS: Any guesstimate when the V4 motors will be in stock, and if so where?
I need a 17.5 for my new 2WD buggy and was eating towards the MMM but wight he V4's now, I think I'd rather have that.
4Likes
