Speed Passion Thread >
Like Tree4Likes
Old 12-09-2012 | 12:27 AM
  #2506
dMITIj's Avatar
So is there no on/off switch with the Reventon Pro?
dMITIj is offline
Old 12-09-2012 | 02:11 AM
  #2507
knighthawk's Avatar
Originally Posted by DaveG28
Hi Solara,
Also, I hav a Reventon pro...is there a more powerful option capacitor than the one included?
Dave,
I asked this question and was told to use this :
Many of our top drivers use the stock capacitor. If you want something better you can purchase the optional capacitor. It offers better overall performance in terms of running cooler, brakes, and other ESC functions.
Part No.# EXT98802-C01
http://www.speedpassion.net/eu/produ...8802-C01&c=OPT
Yes, it's on the esc between the RX and FAN Plugs, doubles as a Setup Button !!
knighthawk is offline
Old 12-09-2012 | 02:32 AM
  #2508
marcel p's Avatar
If i run a reventon pro with my sanwa m 11x and a thunderpower motor and a savox 1257.
Wil i run into problems or wil it work with that.combo?
marcel p is offline
Old 12-09-2012 | 05:33 AM
  #2509
shanelang's Avatar
Default reventon pro failure
Originally Posted by Oldschoolrcer
I had the same issue just two days ago( first time I used it) the driver was not installed properly. I removed all the software and reinstalled it EXACTLY like the YouTube video by speed passion and it works fine now. Try removing and starting over. I spent hours trying to figure it out because everything " looked" right on the pc but for some reason it wasn't working .
Only problem I have now is the first time I went to use the Reventon Pro , I plugged the battery in about ten minutes before the race, and it fried just sitting there on the bench.??? It actually burned the positive terminal right off the circuit board for no apparent reason. I guess i will find out how thier warranty service is now. It went through the Calibration process and bench testing just fine so I don't know what happened. Anyone else have this problem.
Originally Posted by heavy
I have a Reventon Pro that will not program from the card - when you have the program open on the PC and then the card plugged in to the USB and it says connect the ESC - then nothing happens - the PC program doesn't open up with the settings options.
It's not a PC or usb driver isssue because I have another Pro that programs perfectly - anyone had this problem - any help ??
ihad very similar and also now try the warranty avenue, i had battery and usb connected at one point couldn't get any connection that was first week i had it then i got wifi have had sucess on pc and also sucess on wifi with i phone, but just a couple of days ago ,i updated firmware at track and it come up "update failed now my speedy turns on and has nothing wont connect to anything cant even turn it off. i really liked the speedy and wifi stock 0 and stock 1 great changed it at least 10 times lol just for a quick turn.is there a way to reset esc itself cant even enter throttle range calibration i think it is wiped of its program any suggestions. but sadly no more until i find out about there warranty service how did you go with that? thanks shane
shanelang is offline
Old 12-10-2012 | 08:43 AM
  #2510
Originally Posted by texaspaul
I busted the case on a Silver Arrow can I get a new case? Where?
Give our office a call and we MIGHT NOT have the new case for you but we can probably send you a used one, just send postal.....
Solara is offline
Old 12-10-2012 | 08:45 AM
  #2511
Originally Posted by See
Solara,
Did some testing today and I believe pulling that wire has taken care of the problem.
OK....I think the newer generation motor do have motor temperature sensor built in, and we are working on having the REVENTON PRO to read the motor temp without cutting that wire. We will get that update...
Solara is offline
Old 12-10-2012 | 10:33 AM
  #2512
Just put in an order for a reventon pro for my b44.1.
micrors4guy is offline
Old 12-10-2012 | 10:39 AM
  #2513
marcel p's Avatar
I ordered the combo.
Hope it wil work just as reliable as my gt2.0
marcel p is offline
Old 12-10-2012 | 10:50 AM
  #2514
(1) Just make sure SANWA radio MIGHT need to reverse the throttle...it MIGHT, I am not 100% sure...not all SANWA radio are design the same. I have fixed customer with different SANWA radio and some need to reverse the throttle some does not...depends on which model you have. And I do not have M11X to test so I am not sure. It will be one way or the other...easy enough.
(2) If thunderpower motor has temperature sensor built in...cut the 2nd wire on the sensor cable and that will stop the unexpected shut off issue.
(3) I too use Savox servo....if things get out of hand, get a glitch buster. So far, I have 3 cars using the SAVOX servo and REVENTON PRO and none of them need the glitch buster (I am using Futaba 3PKS)
Solara is offline
Old 12-10-2012 | 10:51 AM
  #2515
Again...DO NOT connect the LCD card, with computer and ESC with LIPO batteries, unless you want to have a new ESC and new computer. It stated on the manual.
Now...the latest V21 software (on the website) should able to UNBRICK all the bricked ESC. Please uninstall the old version, and do a clean install...restart Window and give that a try.
Solara is offline
Old 12-10-2012 | 11:00 AM
  #2516
Originally Posted by schumacheracing
ok new video with the fan unplugged and trying to calibrate again with a cap on the reciever so there is no brown out issues
http://www.youtube.com/watch?v=WemMZ...ature=youtu.be
From your video, I am sure you are not even in the setup mode...when you are holding that little round button and turn the on ESC, you must keep holding that round button while the ESC is ON....you hold that button until you hear the BEEP coming out from the TEKIN motor.
My guess is you are not holding the button long enough to get into the setup mode....give it a try.
Solara is offline
Old 12-10-2012 | 11:35 AM
  #2517
Just left message at 888 number.
thanks
texaspaul is offline
Old 12-10-2012 | 12:10 PM
  #2518
Carranza76's Avatar
Is the Rev R not for sale anymore? It does not show up on the SP American website only the Pro, S and Stock
Carranza76 is offline
Old 12-10-2012 | 12:18 PM
  #2519
Autocratic's Avatar
Originally Posted by Autocratic
Is there ever going to be an update that allows the newer Reventon LCD box to work with other Speed Passion ESCs? Because honestly, the $35 LCD programmer plain sucks. Cheap plastic, buttons are terrible. The Reventon box atleast feels like it has some worth to it.
Solara, can you comment on this?
Autocratic is offline
Old 12-10-2012 | 12:23 PM
  #2520
See
The 2nd generation motor does have a temp sensor that was confirmed by Randy Pike from tekin. I will go ahead and run it with the wire pulled until that update comes out.
See is offline
