Speed Passion Thread
#1727
I am building a new Durango 2 wheel drive short course truck and am looking for a good esc set up. I am moving from the Tekin RS to the speed passion GT 2.0 pro.
Any links or suggestions would be appreciated. I looked at the Speed Passion site and there are some older 17.5 and 8.5 set ups, but no baseline set ups for a 13.5.
Thanks,
Thanks,
#1728
Thanks,
Thanks,
if you need a starting point for no boost just standard timing i might be able to help
#1733
I succesfully ran a Reventon R with A Savox shorty servo in my 22 and my brother used the same R in his 22 with a Spektrum A6040. I'm not using Spektrum but he is and neither of us saw any issues.]
I am waiting for the EX to come out and find it strange that the booster doesn't work on the R or S. I was having what turned out to be a timing board issue and successfully ran my R with a receiver pack by pulling the red wire going to the RX. If in a pinch, hook the booster directly up to the battery leads off of the ESC and put the output into the RX while removing the red wire from the ESC lead. This should work without issue as the BEC would be bypassed altogether.
#1737
Here you go.
http://www.speedpassion.net/reventon/home.asp
#1740
I basicly tried every possible way and still not working...if you do have any idea, please share with me...thanks.
4Likes
