Speed Passion Thread
#3827
It's called expandable braided sleeving. It goes over the wire, and you use heat shrink tubing on the ends. I buy it here. I use 1/4" on most of the wires, and 1/8" on smaller wire like the antenna and the my laps.
https://www.parts-express.com/cat/ex...-sleeving/2193
Going to order some today love How clean it looks
#3828
Can you elaborate on what you mean by that? I've got the following three setups that all do the same thing. At 45+ degrees of timing, the cars will not get off the line unless you give them 100% throttle and even then, will hesitate and rattle until the wheels get going.
Reventon Pro + Ballistic 17.5,
Reventon Pro + MMM 17.5 (+40 board),
Reventon Pro + Thunder Power 17.5,
The batteries I am using are Nosram 5600 saddles, Protek 4300 shorty, and Nanotech 4400 shorty. Final drive in all cars is around the low 5s.
#3830
#3832
I need some help guys. I just bought a new reventon pro 1.1 and 10.5 combo for my rb6. I calibrated it with success (esc shut off when calibration was done like it is supposed to), but I am not getting any throttle input. The steering servo works, and the red and orange lights are lit like they are supposed to be. All wiring is correct, and I have tried two different sensor wires. I even tried another motor and still nothing. I hope I didn't get a faulty one. Any suggestions?
#3833
#3834
So the only other thing I have done is hook the speed control up to the programming box and adjust a few things.
#3835
my gt pro 2.0's dont like my mt4 much. when I tried to press the button and turn it on, it would just run 3/4 speed and never calibrate. I flashed it with the HW v3.3 firmware package, tried it 2/3 times , then it worked fine. never had issues with my other airtronics radios.
#3836
#3838
JP Richards throwing down more big TQs and wins at big events using Speed Passion.
http://losiraceresults.blogspot.de/2...-region-5.html
4Likes
