Speed Passion Thread
#3077
I would venture to say it is underrated. I have run the R and S both with a Spektrum DX3S/3100 and have had no issues at all. Even running a Savox on them and I was fine even without a Glitch Buster.
#3079
I also have a pro 4 question . I understand that we can't run any of the boost software but in the mod setting can I at least adjust the punch level and the timing settings available in the LCD box? Its strange to me the PRO would have issues. The amperage ratings aren't far from other ESC that run these motors.
#3080
#3081
David this is the biggest rotor you can use that is legal
http://www.speedpassion.net/shop/det...=RS13803&c=MTR
#3082
BLUETOOTH help needed.
bought and installed one. It worked for a couple changes then stopped when i mounted it in the car. When it is plugged in i get no drive to the motor. However I will retain steering.
When i connect to the phone it will connect but i am unable to make changes then it will say it can not connect.
I have tried it on 3 different reventon pros and it is the same on all of them. I have gone threw the setup mode with it several times and it will not work properly.
Is there something that I am doing wrong? anything that i may be missing in setup or trouble shooting?
#3085
#3087
I've had an issue with an SR300/Spektrum S6040 servo with a Reventon R. Never got a chance to try a glitch buster, but at about 70% travel in one direction it would brown out, go to center then turn again. Repetetive cycle. Could have been the 6040 servo has a small issue, but it didn't happen with my trusty Novak Kinetic. Oddly, it didn't happen with an SR3520 RX either.
#3088
For those running the SC104x4 out there...
I'm swapping out my HW 120A ESC and I want to use my GT2.0 LPF ESC. I am using a 5.5 2pole motor. Does anyone have any suggestions? I'm retiring my B4.1 and want to use the ESC from it in my SC104x4. Need some good setup advice.
MOmo
MOmo
#3089
Does anyone know where online to buy the above ... ? The postage from Speed Passion online store is as much as the card itself putting the cost with shipping at about $75USD ... Extortion if you ask me... Anyone ?
Cheers
Carl
Cheers
Carl
4Likes
