Speed Passion Thread >
Like Tree4Likes
Old 02-02-2013 | 09:55 PM
  #3046
Originally Posted by canon
can the reventon pro compete with the likes of hobbywing xerun, tekin rs pro etccc...???
If you look at last weeks Reedy race, LRP Orion Tekin and Speed PAssion were the top names i say, Actually LRP and SP were the 2 common iI saw, Especially when Associated would show a FB post of the top 3 qualifiers, I saw the Sp name in the top 3 a few times, Never even say the name Hobby Wing. SP actually has some titles and i think On road World champ?
ALIEN3T is offline
Old 02-02-2013 | 11:28 PM
  #3047
AlanHall's Avatar
In the 4wd SC discussion... did i miss information about using something like a 4.5 550 on a Rev pro, or is no one running that anymore? All 4 pole pro4 stuff.
AlanHall is offline
Old 02-03-2013 | 02:05 AM
  #3048
Hi all, I've bought the Reventor R combo with 10.5T motor and i tried to connect the LED program card to PC but unable to detect by the Reventon PC interface, but when I update the firmware, my PC can detect it and upgrade is successful. The steps I connect to PC is
Install Reventon R PC interface > Checked USB Driver is installed > Unplug fan from ESC > Lipo battery is disconnected from ESC > Connect ESC to program card > Connect USB cable to PC, but the PC interface is not detecting my program card, it shows "Please connect to the ESC"
Kindly advice, Thanks
bennychen is offline
Old 02-03-2013 | 02:38 AM
  #3049
Just looked through the "under the hood" pictures from the 2013 Reedy race, and no one is using the Reventon Pro.. They are all using the older 2.0 esc (Hobbywing V2.1).
Anyone know why?
ridgeracer is offline
Old 02-03-2013 | 03:42 AM
  #3050
I've figured it out that the motor need to be unplugged as well, now my PC can detect the led program card finally
Old 02-03-2013 | 08:07 AM
  #3051
Cain's Avatar
Tech Legend
You can use a 4.5 550 pole motor on the Reventon Pro. My buddy does this. Based on what we discussed with Solara the problem they were having when trying to use 4 pole motors was they were trying to do it using boost etc. This is not something recommended to do by tekin which is probably why things were not working.
I am assuming that future testing with 540 4 pole motors will use blinky or MOD software with no timing options turned on and have zero issues.
As perspective, the GT2.0 Pro that I use with my Pro4 4600Kv and previous 4000K was without ANY BOOST. At most, I used 5 degrees of turbo timing but that's it on the 4000kv motor to get more top end since that is when that kicks in. I also went down in gearing as well.
Cain is offline
Old 02-03-2013 | 09:11 AM
  #3052
dvsstrike's Avatar
Anyone know why?
I like the feel of the Gt 2.0 myself. I have three reve pros but the gt has a better feel imo.
dvsstrike is offline
Old 02-03-2013 | 09:29 AM
  #3053
Dork Missile's Avatar
Default Reventon Pro
what are people's opinion? i am running STOCK 0 and STOCK 1 with my reventon depending on the race. as a general rule of thumb,how many teeth should one drop on their pinion size to run boost/and excessive timing? heat doesn't seem to be the issue as the motor/esc don't seem to reach excessive heat levels. what i do notice is the lag coming out of the corners with the larger pinions. Anyone want to suggest?
Dork Missile is offline
Old 02-03-2013 | 09:42 AM
  #3054
Mundy1's Avatar
I also have gone back to my GT 2.0 and 2.1 ESC's
I need to be able to run 4 pole 540 motors in my 4x4 and in my buggy the Gt series just felt better too.
Mundy1 is offline
Old 02-03-2013 | 12:26 PM
  #3055
PastaBoyNY's Avatar
Default Rev pro great... My luck, lousy!
First trophy race in a dozen years. This ESC was flawless!
After a rough start (lost equipment that showed up next day and blown idler gear) I managed a 2nd Plc c-main Finnish and 5th in the B. wasn't too far off pace with a new layout and all the difficulties of the day.
Solara, thank you for the clarification that my settings work well.
It's my pleasure to provide input! Great product and support.
The pro4 will work in Mod2 settings. Just NO boost.. Ever!
Don't need on these motors anyway!!
Have fun gents!
Sal
PastaBoyNY is offline
Old 02-03-2013 | 12:28 PM
  #3056
hairymuffin's Avatar
Anyone know why?
no sure but pictures speak for their selves..even hara uses the gt series,and he is not under contract with no one,and he could have chosen anything.. i also think the reventon pro is larger
hairymuffin is offline
Old 02-03-2013 | 01:28 PM
  #3057
i am going ot try that, since that is the issue i have, Not detecting my esc, But will update firmware. Thanks.
ALIEN3T is offline
Old 02-03-2013 | 06:27 PM
  #3058
Anybody test or have info on what's the best high torque rotor to put in the 17.5 MMM's. Planning on running blinky in RB6 and RT5. There's quite a bit rotors on the site.
kwiksi is offline
Old 02-03-2013 | 06:48 PM
  #3059
Took 1st place and TQ 1/8 expert buggy last night at the Winter Nationals here in socal at revelation raceway with the Silver Arrow v2...Hope you guys dont change too much with the new version...A lot of people are taking notice...Next test will be at the Dirt Nitro Challenge In Arizona feb 20th
Old 02-03-2013 | 07:32 PM
  #3060
Would you mind trying connect ABC pin to Motor but without sensor cable then connect ESC to PC?
WMGary is offline
