Speed Passion Thread >
Like Tree4Likes
Old 02-14-2013 | 08:08 AM
  #3196
Originally Posted by Core Creations
Thanks a ton.. Maybe mine is broke.. I tightened mine but you can still move the timing relatively easy!?
If everything is locked down the the sensor board is still moving freely something is wrong. It might be the white silicon piece is gone or worn out.
Nexus is offline
Old 02-14-2013 | 12:51 PM
  #3197
tazfam2's Avatar
Originally Posted by from_Poland
Hi guys, I'm going to get the Silver Arrow v2 and i have question about the motor. Would this esc handle this motor:http://www.hobbyking.com/hobbyking/s...ackstar%202100
I've read some really good opinions about this but it's rated to 140A. I want to be sure because i don't want to fry the esc.
Thanks.
yes it will work with no problem
tazfam2 is offline
Old 02-14-2013 | 01:28 PM
  #3198
Charlie,
If you need another silicon gasket/ or a different sensor board- give me a call.
Later,
Bill
BSYDOR is offline
Old 02-15-2013 | 11:19 AM
  #3199
Beasty Shout's Avatar
dumb question but, what is neutral range for?
Beasty Shout is offline
Old 02-15-2013 | 11:20 AM
  #3200
2canSAM's Avatar
R/C Tech Elite Member
It is for the amount of deadband on the trigger before the ESC responds. Set at 9% you have to pull the trigger just a slight bit more than with it set at 6% before the ESC responds to the input.
2canSAM is offline
Old 02-15-2013 | 11:28 AM
  #3201
Solara is offline
Old 02-15-2013 | 11:29 AM
  #3202
ahhhhh I see. Kind of like expo? Maybe? I dunno. Thanks though.
Old 02-15-2013 | 11:57 AM
  #3203
Fuzzi0n's Avatar
The way to think of it is the neutral range is the amount you can move the throttle/brake before anything happens.
Fuzzi0n is offline
Old 02-15-2013 | 12:04 PM
  #3204
can anyone suggest gearing starting point for a B4 FT with a GT2.1 Prostock 2s lipo and speedpassion V3.0 17.5T? will be running blinky class. the track is med to high grip and 80X46ft. slightly technical.
Matt
mat3833 is offline
Old 02-15-2013 | 12:15 PM
  #3205
trit215's Avatar
Matt
Try 69/33, if you want more out of the corners go down to a 32 pinion and if you want more on the the straights o to a 34 pinion.
trit215 is offline
Old 02-15-2013 | 12:22 PM
  #3206
damn, looks like i need spurs AND pinions. i think im running a 72T spur and 22T pinion....
Matt
mat3833 is offline
Old 02-15-2013 | 12:29 PM
  #3207
trit215's Avatar
Matt, your running stock 17.5 class right? Thats kind of a general gearing for the b4/b4.1/b4.2 when racing stock.
trit215 is offline
Old 02-15-2013 | 12:32 PM
  #3208
i will be running 17.5T blinky if im not mistaken. may move to mod if im still as good as i used to be tho, lol.
Matt
mat3833 is offline
Old 02-15-2013 | 12:38 PM
  #3209
Cain's Avatar
Tech Legend
pinion is a 26T
He is running a V3.0 Competition 17.5 motor with the black standard timing board.
What boards are you guys using in general?
Cain is offline
Old 02-15-2013 | 01:00 PM
  #3210
trit215's Avatar
Matt
Ok cool, yeah that should be pretty good for stock class, but I don't know about mod class gearing because I race stock.
trit215 is offline
