Speed Passion Thread
#3183
So for running a Pro on a Novak 7.5L, do I need to disable the temp cut-off AND cut the sensor wire? Or will just disabling the cut-off do the trick.
I won't have much time to play with this before I have to throw it on the track for a 30-minute enduro run in a few weeks. I'll be lucky if it even shows up from the retailer in time.
#3184
Hi guys, I'm going to get the Silver Arrow v2 and i have question about the motor. Would this esc handle this motor:http://www.hobbyking.com/hobbyking/s...ackstar%202100
I've read some really good opinions about this but it's rated to 140A. I want to be sure because i don't want to fry the esc.
Thanks.
Thanks.
#3185
JP Richards, Dustin Richards, and Mike Frazier all make A Mains at Round 1 of the J-Concepts Offroad Series.
http://teamspeedpassion.com/2013/02/...eries-round-1/
#3186
Thanks.
Thanks.
#3189
if you want more timing that what you see, you will need different sensor boards.
For 17.5 blinky I know in other motors its common to go big time on the timing. What boards are you guys finding you use on indoor tracks in 2wd buggy stock?
#3190
Check to see what timing board is currently inside the motor to determine your total amount of timing. You can also purchase any of the optional sensor boards for your application.
http://www.speedpassion.net/shop/ind...=sensor%20unit
#3191
SP,
im trying to send in my esc for repair,I got a rm# but when I try to input the pn# and item description it will not let me and I cant go to the next step in shipping my item..I even tried using a different browser? Can I get the address and ship my item?
#3192
Be prepared it takes time.
#3193
#3194
4Likes
