Speed Passion Thread
#3947
I am having an issue with my Silver Arrow V 2.0. How do i get more braking out of it ? i have re-calibrated my radio to the ESC and verified all my setting are at 100% on the radio and the ESC.
I am aware that the Silver arrow uses a proportional braking system but i was wondering if there is way to by-pass or strengthen the brakes.
BTW i have 2 of theses ESC's and they both do the same thing one in am 8th scale buggy and the other in a 4wd SC truck.
any help will be greatly appreciated.
#3949
#3951
Thanks for the help, if you can think of something that i may have over looked LMK
#3952
Cain i have tried it in all 3 modes ( fwd/brk, fwd/rev, fwd/rev/brk) with reverse set at 100% and brake set 100%. when i press brake on the radio it slows the car down but it doesn't lock the wheels. I'm aware this is designed so that the vehicle doesn't break gears under hard stopping, but i like to dial out the brake in my radio.
How many cell you are running?
BR
SP Tech
#3956
#3957
very strange about the 1/8 buggy. I could flip mine with how hard the brakes acted.
As for the one of 2S, it is not recommended for that.
can you post your full setup of electronics?
#3958
as far as ESC settings
running mode = for/rev
drag brake force = 5%
voltage protection = 3.2v
DRRS punch = level 9
Brake Force = 100%
Reverse Force = 100%
Initial Brake = 40%
Neutral range = 6%
AMTS Timing = 8
Motor Rotation = CCW
Lipo Cells = 2 Cell
I also noticed that when i press full brake on the radio the LED on the ESC goes to red then changes to red/green once the tires stop turning .
if i go full throttle the red/green led's both turn on
i hope this helps
4Likes
