Speed Passion Thread >
Like Tree4Likes
Old 03-05-2015 | 06:12 PM
  #5446
Speed Passion corporate is aware and it's a server issue that's being investigated.
North American customers can still visit http://shop.speedpowerrc.com/
Nexus is offline
Old 03-05-2015 | 06:15 PM
  #5447
jjahn's Avatar
Thanks for the reply, thats good to know. Sucks that's happening.
jjahn is offline
Old 03-05-2015 | 08:38 PM
  #5448
71schaeffer's Avatar
Hey Nexus can you tell me what it looks like when the Reventon S is in blinky mode? I put the timing to 0 but i didnt know what te colors should look like
71schaeffer is offline
Old 03-07-2015 | 10:57 PM
  #5449
GeekSpeed's Avatar
Hi all.
I just installed the Reventon R and 3.0 MMM 17.5 combo I bought in my 2wd buggy. I downloaded the latest firmware, charged up the battery, made sure the RX was working correctly, and installed it in my buggy. I went to calibrate the throttle, which seemed to work, and then when I powered the it back on, nothing. I pull the throttle, I get nothing. Trying forward and backward is the same result. I can steer, as the steering servo is fine, and I know it is not the radio or receiver. I charged up the battery and even tried a different one. Nothing. I have re-calibrated several times, as per the instructions and the YouTube video. The lights go on and off as they should, and the ESC beeps, etc. All the connections are correct. Am I missing something, or is my setup (I am thinking motor, most likely) DOA? Any suggestions?
GeekSpeed is offline
Old 03-17-2015 | 09:08 PM
  #5450
DuncanT4.2's Avatar
I went to update my Reventon S firmware and first I noticed that "Mod 2" was an option, I never noticed that in the past. I also noticed that Modfied 2 now has Forward/ Reverse with Brake as an option. Is this a new update or something?
DuncanT4.2 is offline
Old 03-21-2015 | 07:02 AM
  #5451
Yea just a new update, I've been running my Reventon S 17.5r combo for about a month now on Fridays and Saturdays and i love it! System doesnt get hot, motor geared at 76/32 on a medium to small indoor track barely gets up to 130deg with 10deg of timing. I'm keeping up with the majority of the people at my track! When i add 18deg of timing for Super stock class man does this thing wake up! I've been really happy with it. I think i am going to get the Reventon R with 8.5 combo to try to mod class.
Old 03-24-2015 | 07:03 PM
  #5452
GW
Does anyone know the actual motor turn limit for the Reventon S speed control. My manual says 7.5, the site I bought it from says 9.5 and another site says 10.5.
Any help is greatly appreciated.
GW is offline
Old 03-24-2015 | 08:24 PM
  #5453
DuncanT4.2's Avatar
How do I delete this post? I accidentally posted twice.
Old 03-24-2015 | 08:25 PM
  #5454
DuncanT4.2's Avatar
http://www.speedpassion.net/reventon/home.asp
Old 03-24-2015 | 08:29 PM
  #5455
DuncanT4.2's Avatar
I believe the Reventon S can handle 9.5t max, but be cautious adding too much timing running that combo. I run my Reventon S with the Speed Passion MMM 10.5 T with the standard 15 degree timing on the endbell of the motor, and sometimes go up an extra 11 degrees timing on the ESC programming. This is on a Associated T4.2 and im slightly undergeared at 17 / 84.
My manual says 9.5t max, its the V2.1 Created Nov 5th 2013. I do see where the V2.2 Manual created Nov 28th 2013 says you can go to 7.5t but that has to be a misprint. The Reventon Stock Club Race is a 40amp non-timing advance ESC and it can handle 8.5t, so the Reventon S also being a 40amp ESC but with Timing Advancing should not be able to handle anything less than 8.5t as more timing creates more heat. I recommend going with a 10.5T and if you need more power just advance the timing, you have 11 - 20 degrees of adjustability on the MMM motor and up to 26.5 degrees extra on the ESC, that should be more than enough. Remember to get your gearing right before you start messing with timing though. Hope this helps.
Old 03-24-2015 | 09:51 PM
  #5456
MOmo's Avatar
Ok, i thought i found the right cable to use with my tablet and the digi program box.
I'm told that you can use the app (i dont want the Bluetooth adapter) and connect to the box for programming.
what is the proper size usb end for the program box? I know that my tablet is the micro usb.
The 2.0 usb is too big.
Momo
Attached Thumbnails Speed Passion Thread-1427259126215.jpg   Speed Passion Thread-1427259235182.jpg
MOmo is offline
Old 03-24-2015 | 10:47 PM
  #5457
GW
Thanks. I agree the 7.5 must be a misprint since the Reventon R is a 7.5 limit. Didn't make sense that the S would be the same. Thanks again.
GW is offline
Old 03-27-2015 | 10:24 PM
  #5458
Jpdanger's Avatar
Where is the Reventon app in the iTunes store? It isn't in the US app store, nor the Hong Kong app store as listed in the instruction manual.
I just purchased the WiFi module, but it's useless without the app, right?
Jpdanger is offline
Old 03-27-2015 | 11:40 PM
  #5459
HSV427's Avatar
I bought a top dollar orion esc thinking there the best and before i even got it on the track it was faulty, then purchased a gforce which decided to catch fire for no apparent reason and ended up with a speed passion reventon, and let me tell you at half the price off the top dollar esc it has been twice as good as any esc I've owned, i will now only ever run reventor there unbelievable.
HSV427 is offline
Old 03-28-2015 | 09:27 AM
  #5460
I have many SP setups and are now using them exclusively. But be aware SP has their problems too. They have terrible customer service and take forever to return warrantied items. I had a speed control fry and returned it, it took 3 months to get it back. The only reason I still use them is because their cheap and usually run very well. I have backups in case something does happen. They're cheap enough where you can have the backups. I use to be a Tekin fan but have had trouble with them too. The problem with Tekin is they are so expensive I cannot afford to have backups although I have heard they have a very good return policy. I just cant wait that long for service.
evodawg is offline
