Speed Passion Thread >
Like Tree4Likes
Old 02-18-2015 | 07:50 PM
  #5416
jnelson214's Avatar
Where can i find current set up sheets? I only see set ups from 2011 for stock buggy Or stock SCT. Thanks.
Not sure if it matters, the buggy runs GT 2.0 and SCT runs Revention pro
jnelson214 is offline
Old 02-19-2015 | 08:36 AM
  #5417
Default Help
I have a GT 2.1 Prostock and was just cleaning my truck and now when I turn on the speed control it gives lots of short beeps. Then just random short and longer beeps. The steering still works fine but nothing with the motor. Ideas?
mark in wi is offline
Old 02-19-2015 | 08:58 PM
  #5418
You racing at Timewarp or RaceEm?
Try reloading software and calibration. Not sure how you cleaned but hopefully nothing shorted out.
Fun stuff from Speed Passion.
Like and share this photo on your Instagram or Facebook page and I'll send you a 10% off code good on Speed Passion's online store. Make sure you use #speedpassion so I can see it online.
Nexus is offline
Old 02-20-2015 | 10:21 AM
  #5419
Thanks Nexus!! I reset and everything and now it works. I think I got some simple green on the switch and between drying and the the recalibration everything works again.
Old 02-20-2015 | 10:50 AM
  #5420
jnelson214's Avatar
Mostly at Timewarp and I have not been out to Race Em but i plan too.
Old 02-23-2015 | 08:50 AM
  #5421
awesome.
You can ask Blinky Blake or even Jake McGuire. Blake runs the Reventons and Jake used to before he signed with AE/Reedy. In any case, if you're running stock I would max the DRSS or run at least 7. Disable heat and voltage protection. Brake settings are more driver preference. In SC I was running somewhere around 80%.
Nexus is offline
  #5422
V4 spec motors are now in stock and available!
http://shop.speedpowerrc.com/competition-v4-0/
We've had a lot of our top spec drivers testing them in 17.5 2wd buggy, shortcourse, 13.5 wheeler, USGT, TC, and all the other spec classes. Everyone has given positive feedback and noted they run faster with less heat than other motors they were running.
Nexus is offline
Old 02-23-2015 | 10:35 AM
  #5423
JBR18's Avatar
Just received the Bluetooth device for programing the ESC works great, no laptop needed.
JBR18 is offline
Old 02-23-2015 | 01:23 PM
  #5424
jnelson214's Avatar
awesome.
Thanks, I'll do that. I am close to what you suggested just from experimenting around with it. thanks again!
Old 02-28-2015 | 04:23 PM
  #5425
Hi guys I'm new I have a speed passion reventon s that's not working. I installed it on my kyosho zx-6 with a reedy 13.5 motor ran great then it stopped. I checked it over and the power wire on the capacitor came off. I soldered the wire back on and still no go. The program box still connects and the lights are not blinking and on but still it doesn't work I opened it up to see if any thing is fried and I did not see anything cooked. Is there anything I can do?
Chitenator is offline
Old 02-28-2015 | 04:33 PM
  #5426
JBR18's Avatar
Try reprogram? Mine just stopped after 2 min run and the box showed all was good. I reprogramed it and its fine.
JBR18 is offline
Old 02-28-2015 | 06:05 PM
  #5427
You can also fill out an RMA and send it in for service.
eragot is offline
Old 02-28-2015 | 06:11 PM
  #5428
I bought the esc last year and have no warranty card that I know of I'll check it out and I'll update the software see if that works.
Old 02-28-2015 | 07:22 PM
  #5429
I fried mine and it wasn't covered by warranty. I also have to call them to see what the story is with another I sent to them. The first one was reverse polarity, the second, I don't know. However, the second was purchased second hand, so I have no idea about warranty.
The RMA is just so they can track it I think.
eragot is offline
Old 03-01-2015 | 08:04 PM
  #5430
Well is there a way for a repair service?
