Speed Passion Thread >
Like Tree4Likes
Old 09-23-2013 | 05:18 PM
  #3916
how do you change speed passion reventon pro to run blinky? thanks guys
ldog is offline
Old 09-23-2013 | 05:32 PM
  #3917
wild gopher's Avatar
Load the Stock0 software on the box and let it rip.
wild gopher is offline
Old 09-23-2013 | 09:32 PM
  #3918
What software do you need to run with a GT2.0 pro for 17.5 blinky?
knowitall156 is offline
Old 09-24-2013 | 05:37 AM
  #3919
508stock for the gt
clintscreations is offline
Old 09-24-2013 | 08:49 AM
  #3920
I was trying out the Mod0 and Stock1 firmware and noticed that Mod0 is a lot smoother at very low throttle. Stock1 will smooth out after I'm past 1/4 throttle, but less than that, it's very notchy and loud. Is this normal and is there anyway to smooth out Stock1?
jha07 is offline
Old 09-24-2013 | 09:02 AM
  #3921
1967Typhoon's Avatar
Are you running a sensored motor? Double check your sensor connections if so.
Also, after every software swap you should recalibrate the ESC to the Transmitter.
1967Typhoon is offline
Old 09-24-2013 | 11:00 AM
  #3922
Yes it's sensored. Seeing as the problem goes away when I switch back to Mod1 firmware, I can't see how it can be bad wiring.
I'll try recalibrating the esc, but the set points seem ok when I tested it.
jha07 is offline
Old 09-24-2013 | 08:22 PM
  #3923
xrayrc's Avatar
What's the recommended profile an settings for a reventon pro and 550 SC motor in a Losi scte?
xrayrc is offline
Old 09-25-2013 | 09:07 AM
  #3924
Cain's Avatar
Tech Legend
by 550, you mean 2 pole right?
Cain is offline
Old 09-25-2013 | 11:15 AM
  #3925
Originally Posted by clintscreations
508stock for the gt
Thank you Sir.
Old 09-25-2013 | 05:11 PM
  #3926
Originally Posted by knowitall156
Thank you Sir.
anytime!
Old 09-26-2013 | 12:40 PM
  #3927
Mark McCoy's Avatar
which is best on off road 4 whl mod 1 or mod 2 ??
Mark McCoy is offline
Old 09-26-2013 | 03:04 PM
  #3928
would the R be powerful enough for a DEX410
cripplethreat is offline
Old 09-26-2013 | 03:14 PM
  #3929
if you havent purchased yet, spend the few extra bucks and get the pro. Ive seen them around $100 shipped on ebay.
Old 09-26-2013 | 05:27 PM
  #3930
Mod 2 is probably better. Should run a bit cooler. But either will work
slowguy2012 is offline
