Speed Passion Thread >
Like Tree4Likes
Old 09-14-2013 | 01:53 PM
  #3901
Fast410's Avatar
Originally Posted by Nexus
Download the SP Reventon PC Interface and make sure all your settings are correct.
Reventon PC Program with USB Driver V1.1.0.22
ok I did that still no change.i have a 4pk radio already tried changing reverse on it .that just makes the motor run in same direction in either way u pull the throttle
Fast410 is offline
Old 09-14-2013 | 03:28 PM
  #3902
trx450racer174's Avatar
Ok so you have reversed the throttle in the radio and reprogrammed the esc again for the throttle epa and neutral???
Sounds like your missing a step somewhere cause we have ran this ESC on multiple radios and never had a problem with getting the motor to turn the correct direction.
trx450racer174 is offline
Old 09-14-2013 | 10:54 PM
  #3903
1mrdad's Avatar
Originally Posted by 1mrdad
I have a Reventon Pro using stock 0 software for 17.5 blinky buggy class. When I first turn on the esc, the leds are normal with the red blinking and the amber solid. However, now when I get done with a 6 minute heat or practice, the red and amber are blinking alternately like a train crossing AND/OR both leds are blinking at the same time. LVC is at 6.8, heat protection off. After a 6 minute heat, the batteries voltage is 7.9v-8.0v and the esc temp approximately 115* or lower. If I shut off the esc and turn it back on, the leds are blinking normal again. The esc functions normally with the abnormal led blinking. Brakes, throttle, and steering are all ok. I've had the esc about a year now, and the abnormal blinking just started about a month ago. I just wondered what the abnormal blinking means...
Anyone? I don't know if it's related, but tonight on the first lap of the 3rd qualifier, and during the first lap of the main, I lost throttle, but I had steering. As soon as the esc was shut off and turned back on, throttle worked..
1mrdad is offline
Old 09-14-2013 | 11:34 PM
  #3904
onekiwi's Avatar
Any thoughts about using a SP V3 with a LRP SXXTCV2 .. after a minute or so I get:
Yellow/Red
(same time) Motor Failure
1. sensor wire missing or defective?
2. drivetrain stuck?
3. motor defective (locked rotor, damaged sensor)?
I try another motor and its fine, I try the motor on a different esc and thats fine, is there a compatibility issue with the esc/motor?
onekiwi is offline
Old 09-15-2013 | 05:57 AM
  #3905
Can you tell me your motor is rotating COUNTERCLOCKWISE or clockwise..? It suppose to rotate in COUNTER CLOCKWISE direction. I just read thru the 410 manual and if your motor is rotating COUNTER CLOCKWISE, your 410 should move FORWARD.
Please check your 410 manual page 34 step 21 and check the diff position...front diff should be facing DRIVER side and rear diff should be face PASSENGER side...
Your SPUR gear on your 410 MUST rotate CLOCKWISE (if you are looking from the back of the car)....according to the manual, this direction is suppose to make the car go forward.
Solara is offline
Old 09-15-2013 | 06:37 AM
  #3906
Fast410's Avatar
thanks a guy on 410 thread told me flip the diffs also,my son built the buggy so i did not know that would make the car go in reverse,i always ran 2 wheel buggy..thanks for the help....he will be happy to know he can still run his speed passion stuff,.....
Fast410 is offline
Old 09-22-2013 | 04:09 PM
  #3907
zeakemedia's Avatar
Will the program box from my GT 2.0 LPF work on a Revention R?
Blake
zeakemedia is offline
Old 09-22-2013 | 06:05 PM
  #3908
Blake
No. You need the blue programming card.
Nexus is offline
Old 09-22-2013 | 06:27 PM
  #3909
zeakemedia's Avatar
Thanks man.
Blake
Old 09-22-2013 | 07:52 PM
  #3910
Wildcat1971's Avatar
I picked up a speed passion 17.5 v3.0 comp motor, the non mmm. I am running it in my kids tlr 22 with 31/70 gearing. It seems overly torquey and tops put very quickly. I was going to gear up, but I am not sure temp would allow that. I also turned the timing all the way up and the esc is blinky. Thoughts?
Wildcat1971 is offline
Old 09-23-2013 | 04:14 AM
  #3911
Keep going up on pinion while making sure temps don't go higher than I'd say150f max and or you max out 3/4 of straight. Some say higher on temp, but I don't like going higher personally.
I'm t 69/33-34 on a 17.5 MMM with more timing.
kwiksi is offline
Old 09-23-2013 | 10:20 AM
  #3912
Devin's Avatar
Anyone know if the ESC that ships with the Durango rtr's are adjustable, and if so, how? I cannot locate instructions for it, could anyone link me or scan their manual? I am interested in turning down the punch.
Devin is offline
Old 09-23-2013 | 11:59 AM
  #3913
Cain's Avatar
Tech Legend
that's cool you got a torquey one to be honest. Do you know if it had the 12.5mm rotor in it Wildcat1971?
Cain is offline
Old 09-23-2013 | 12:02 PM
  #3914
no idea. I geared it the same as I do my reedy's and its WAYYYYY slower, but has way more punch. It probably just needs alot more gearing.
Old 09-23-2013 | 04:36 PM
  #3915
jha07 is offline
