Speed Passion Thread >
Like Tree4Likes
Old 03-06-2014 | 06:21 AM
  #4651
Hi,
My max epa is 120%....so you think re calibrate at 100%?
sunktothenutz is offline
Old 03-06-2014 | 07:02 AM
  #4652
Originally Posted by AlanHall
when running the blaze 5700 in sct do i need to be able to use timing or boost to take advantage of it ?
Sorry for this late response. I don't use any timing or boost in my Blaze 5700.
b4wires is offline
Old 03-06-2014 | 11:19 AM
  #4653
Default Speed Passion Reveton Pro V1.1 ESC
I just purchased one of these ESC's along with a Speed Passion Blaze 550 4 pole 4600kV Motor for my Losi SCTE 4x4. Is anyone else running this combo? If so I would like to hear your comments good or bad. I would also like a recommendation for a good starting set up for the ESC. I just placed the order yesterday so I should see the shipment very soon. Feeling excited. Hopefully its a lot more durable than the Hobbyking crap that I had. Thanks
Gordon.
Acemechanic is offline
Old 03-06-2014 | 11:50 AM
  #4654
1967Typhoon's Avatar
The Reventon isn't really meant for 4-pole 550 cans. That is asking a bit too much from that ESC. If you are dead set on running that combo, do not add any timing or boost from the ESC! I would also turn punch levels down to a low level.
1967Typhoon is offline
Old 03-06-2014 | 07:04 PM
  #4655
Originally Posted by sunktothenutz
Hi,
Yes 100 for brake and throttle.
let us know your results
clintscreations is offline
Old 03-06-2014 | 09:58 PM
  #4656
Why do you say that running the Reventon would be too much for this combo? I read on the Speed passion web sight that running the Blaze 550 & the Revention with turbo is a perfect combo for the 4x4. Here is what I read copied and pasted right from the web sight. I may be wrong on it being a 4 pole motor. It does not say in the specs of the motor how many pole motor it is. However I purchased the motor and ESC from Express Hobbies. In there ad it states it as being a 4 pole. Hopfully when it comes the paper work will state what it is. I have a 2 pole 550 Hobbyking 4x4 motor that I can use if this ESC doesn't work well with a 4 pole motor. My money is on the line on this combo.
Blaze 550 1/10 4x4 SCT series Brushless motor - 4600KV for SCT 4x4, 5MM Shaft. Ideal for 1/10th scale 4x4 Short Course Truck Racing. Perfect for Reventon Series ESC running boost or Turbo software on MOD racing. Motor came with built in cooling fan inside the motor for extreme cooling and increase overall performance.
Old 03-06-2014 | 11:39 PM
  #4657
OK will do,thanks.....just out of interest,why do we set them at 100% and not,if possible on the TX 120%?
Old 03-07-2014 | 05:06 AM
  #4658
When I first started using sp I was told its a software thing.
Old 03-07-2014 | 05:09 AM
  #4659
AlanHall's Avatar
Its not 4pole. I have it in my sct410 on a sct-pro with no timing and it seems to rip. I haven't had it on the track yet . but I have a 4pole to test against once I make it out . I believe they suggest the 1.1 with the blaze motors too.
AlanHall is offline
Old 03-07-2014 | 05:51 AM
  #4660
I didn't realize it wasn't a 4-pole. Almost all 550 can motors meant for 4x4sct are 4-pole. The motor you have is the first one I have seen that isn't a 4-pole. Since it is a 2-pole you should be fine. Disregard my previous comment.
Old 03-07-2014 | 06:34 AM
  #4661
That's incorrect. Almost all 550 motors are 2pole. There are some exceptions, but the majority are 2pole
The Blaze will run fine on a Reventon Pro, old or 1.1. I didn't run the 4600 but the 5700, with boost. The ESC worked just fine.
I believe my DRRS was Level 3, Timing was 3* slope at 9000k up to 120k.
J.Pietsch is offline
Old 03-07-2014 | 06:42 AM
  #4662
Yeah I guess as far as sensored 550 motors go , you are totally right. As far as unsensored 550, seems like most are 4 pole. I clearly don't know enough about the 550 motors. Oops.
I will just shut my mouth and leave now.
Old 03-07-2014 | 07:20 AM
  #4663
No worries. There are so many options out there these days it's hard to keep them all straight.
Old 03-07-2014 | 09:39 AM
  #4664
Resqnu's Avatar
Default SP Reventon Pro and Savox??
Anyone having issues running a SP Reventon Pro with a Savox 1256tg in a SC10.2? I have a new Savox 1256tg I was going to run, but wanted to make sure of no issues first.
Resqnu is offline
Old 03-07-2014 | 09:56 AM
  #4665
the incubus's Avatar
I was running that Servo with my Tekin RS Pro and had issues with browning out constantly. I then switched to SP and the browning out issue rarely presented itself. I then switched to an MT-4 radio and have not had a single issue since.
I think the Sanwa Rx's are simply better engineered than Futaba at this point. If you are running a Futaba radio you're going to want to run a glitch buster as well. I could've done that myself, which, for my 4.2 would not have been an issue but on my 410, it's so short on space I simply opted to switch radios and upgrade my son's radio with my hand me down.
the incubus is offline
