Speed Passion Thread
#4622
Being in a wheelchair if I hit a pipe or get stuck in the corner reverse is extremely important. I understand in racing its not need but practicing it's nice to not have to wait for someone else to wreck to get unstuck
#4623
[QUOTE=Scargoes;13035782]#1: make sure the spur/pinion mesh isn't too tight, Use the paper trick to set mesh. Take a small piece of notebook paper and set it between the spur and pinion and slide the gears together tight, tighten down the motor screws. rotate the gears to remove the paper. Mesh should be correct. Drivetrain bind is a sure way to generate excessive heat.
thanks for the info. I always run my gear mesh a little on the loose side so i know that is not the issue.
i found on speed passions website the specs for the motor. They say 4.8-6.0 FD ratio. i calculated it with both setups, first with the 70/29 i am at 5.86 FD. With the second setup 76/30 FD is 6.15. am leaning towards a defective motor, what do you think?
#4627
Two questions
First does anyone know where I can get pro LCD box for the gt series esc
Second prostock esc can handle lower turn motor if I change the software. But can I run a lower turn motor if I turn off the supercharger settings
#4628
My reventon pro looks like it may have died this weekend. Was running in a b4.1 with a competition v3.0 17.5 running stock0 firmware, geared 35/72. esc never got more than a couple degrees above ambient, motor 50C max. Worked fine for practice, qualifying, 2 mains, then when I went to run the third main it turned on fine, steering worked fine, but pulling the throttle gave nothing. recalibrated, still nothing. give it a slight push though and if off the ground the wheels will spin, but when on the ground it coggs very very badly.
obviously replaced the sensor cable, which made no difference. motor still works fine with an xerun 60a so thats not the problem either.
esc was purchased via speedpassion au warehouse on 18th August 2013, and only has at most 20 runs on it.
Any suggestions/ideas/anything?
#4629
I run a reventon R in my DEX210 with a 17.5 MMM and timing at 20deg with 34/69 gearing motor temps always around 70-80deg after 5 min races.
sounds terminal only suggestion I have at least there cheap to replace
http://www.walterrchobby.com.au/inde...-esc-blue.html
http://www.walterrchobby.com.au/inde...blue-5603.html
#4631
Can you try and update the software to see if it doesn't reset all parameters?
Longshot, but worth a shot I think. Also look for any stray strands of wire shorting on a different contact point. A friend of mine had this on his RS Pro last year and it ran fine for a little over a month but all of a sudden it shot a puff of smoke and he didn't see anything wrong but I took a peek and immediately saw the single strand reaching out and was actually soldered to a different point. It was from one of the motor leads to another which is likely why it worked for so long, but eventually proved too much and burnt it up.
#4632
| + YouTube Video | |
#4633
Only thing I can think of is I had a issue really bad cogging wouldn't move unless I either full throttled or gave the wheels a spin, problem was my sensor board put a spare in and it was all good.
i know you tried it with a Xerun ESC but its like the revention always need good Sensor feedback otherwise they dont like it at all.
Logic tells me the the ESC aint right internally, sadly support from SP can be lacking, Solara on here can normally assist or give some advice send him a PM
4Likes
