Speed Passion Thread >
Like Tree4Likes
Old 02-26-2014 | 09:22 AM
  #4636
cbass722's Avatar
does anyone know what the lastest firmware is for the lcd program card. I looked all over their site and cant seem to find it. when I checked for updates there were like 4 or 5
cbass722 is offline
Old 02-26-2014 | 11:04 PM
  #4637
hairless_ape's Avatar
Anyone know the approximate number of turns for the 3500kv sensorless motor? Bought the combo with Reventon S for my son's buggy and I'm trying to figure out where to start for gearing.
hairless_ape is offline
Old 02-27-2014 | 12:05 AM
  #4638
dan_vector's Avatar
dan_vector is offline
Old 02-27-2014 | 01:59 AM
  #4639
RCaddict0's Avatar
A 3500 motor is about equal to a 10 turn motor. Varies between manufacturer, but..
Did you pick up the combo on Ebay? I just bought the revention s/ 3500 combo w/ prog card for $49.99 w free S&H! Simply cant beat it!
RCaddict0 is offline
Old 02-27-2014 | 08:56 AM
  #4640
That is the deal I got, but I purchased it through rcmart.com not the eBay store. Bought 2 other ESC's at the same time and saved $14 on their site over the eBay store.
Old 02-27-2014 | 11:34 AM
  #4641
hairymuffin's Avatar
I have been a speedpassion fan boy since they 1st came out...Recently i have been disappointed with the motors...I have had 3 v3.0 motors rotors come apart..a 7.5,9.5,17.5...plus 2 more motors just up and fry??? WTH? My son is a pro driver and I cant have these issues racing at a top level..Anyone else have these problems with motors? can the rotor be put back together using jb weld?
hairymuffin is offline
Old 02-27-2014 | 12:06 PM
  #4642
heinen81's Avatar
I have been running 2 Reventon R 17.5 systems in 2WD SC and 2WD Buggy with allot of success and no problems as far as rotors. The only issue I have ever had was a stock timing board with minor cogging. Were the temps getting up there pretty high? I don't think mine ever went over 155*, so maybe that's why I haven't had an issue.
heinen81 is offline
Old 02-27-2014 | 12:46 PM
  #4643
the incubus's Avatar
I've been running a 7.5 for a solid year and now an 8.5 for 3 months and have had zero issues. The 7.5 was on my 4.1 all that time and it took some serious abuse, the likes of 8th scale douches smashing into me and/or knocking me into the pipes and walls. I think you need to examine your motors to see if they share any similar marks or signs of damage.
As for JB Weld, I don't think you should even consider that because the rotors are balanced to ensure minimum vibration. Using JB Weld will more than likely result in an off balance rotor, unless you figure out a way to leave a perfectly uniform amount at the joint.
the incubus is offline
Old 02-28-2014 | 04:23 PM
  #4644
nexxus's Avatar
Super Moderator
Has anyone had issues with the Reventon S and LRP X20 motors? I run an XB4 4wd in Blinky 17.5 and have run 29/72 gearing the past 6 months, motor came off usually at 140, the past 4 weeks I have changed from an LRP speedy to the Reventon S as I like the feel of the drag brake a lot better on the speed passion but the motor is now coming off at 180-190. ESC Temps are fine, LED card says it comes off at 45-50c. I have not changed anything on the motor, still running the std 30 degree insert, checked bearings and they are fine, no drivetrain binding etc
nexxus is offline
Old 03-01-2014 | 06:30 PM
  #4645
heat wasnt an issue..Im just gonna buy some new rotors..Its a lot cheaper
Old 03-03-2014 | 10:19 AM
  #4646
I need some help with gearing on the Competition V3.0 Brushless Motor - 17.5R
I am running a Durango DESC210 with the gearing at 75/26 on a medium to large size track. The problem that I was having is that after a 5 minute heat the motor came off at 185 degrees but was fast until the last minute or so. When I geared down one tooth to a 25 then the thing was really slow and came off after the 7 minute main at 155 degrees. One other issue I had was that I was not able to clear the triple like some of the other trucks were able to do, did not feel like enough torque to take off as the run up to the jump was short. I have the yellow board installed and set at what I believe to be 35 degrees of timing. I can see the potential in this motor just need help getting it set up. Thanks for any help on this.
fanfor18 is offline
Old 03-03-2014 | 12:10 PM
  #4647
Cain's Avatar
Tech Legend
have you tried going with lower timing and then bigger gearing? Maybe try a green board next.
Where are you topping out down the longest straight with your motor?
Cain is offline
Old 03-06-2014 | 12:51 AM
  #4648
Hi,
I have a reventon S running a SP 13.5T motor.....the problem is I lose brakes sometimes...any ideas??
sunktothenutz is offline
Old 03-06-2014 | 04:34 AM
  #4649
Maybe try like 78 spur.
clintscreations is offline
Old 03-06-2014 | 04:37 AM
  #4650
Originally Posted by sunktothenutz
Hi,
Is your radio end points at 100% high and low on the epa.
I had mine set to max, Ioaned my radio to someone using other sc, I had the same feeling of brake loss.
