Speed Passion Thread
#3136
I recently picked up a new speed passion reventon and it seems to hit LVC really early. Not sure if its an internal problem or something else is causing it. The motor and esc are running cool, so I don't think it is hitting the temp cut off. I bought some other lipos thinking my lipos are going bad but the same thing is happening, and the lipos are fully charged and balanced. LVC cut off setting hasn't been touched. Everything is plugged in correctly and nothing is loose. Not really sure what else could be wrong. Let me know what you guys think.
#3139
http://www.speedpassion.net/reventon/home.asp the far right tab for firmware and set up sheets, tells you all the reventon ESc's whats preloaded, and what each ESC can run.
#3140
That's LVC. What is your current setting? What "C" rating are your packs? What kind of batteries? If you have not changed your LVC settings then it should be set at No Protection. It sounds like your batteries can't keep up with your motor/esc amp draw. I had this happen with some cheap 15c lipos on a Hobbywing ESC. I had to run the lowest punch (DRRS in Speed Passions terminology)possible. When at idle throttle are both the Red and Orange LED should be solid if running sensored mode.
#3142
im about to be receiving a Black GT2.1 Prostock and 17.5T motor that i will be running in a B4. i cant seem to find the page to download different profiles(aka blinky, mod, etc). anyone care to throw me a link? it will already have the blinky profile loaded(thanks cain!
) but id like to be able to switch to mod when i feel the need.
Matt
Matt
#3143
#3145
#3146
#3147
The current settings on my reventon stock club esc is all the same other then changing the brake to 80%. I'm using a 40C lipo battery, and actually ended up picking up some other batteries (same C rating) thinking my old ones where going bad. The light is red and orange before it acts like its in LVC. But what you said makes sense, maybe I'll try dialing down the punch.
#3148
Hi,
I have a question about the warranty. I would like to buy Silver Arrow v2.0 for my Caster Racing EX-1.5. I live in Europe and as i can't find it anywhere here i want ti buy it in US (at A main). And here is my question do i the warranty or not buying it outside the Europe.
Thanks in advance.
Thanks in advance.
#3149
Hi,
Thanks in advance.
Thanks in advance.
Speedpassion states this on their website:
Speed Passion product sold to dealers and consumers in the USA is for USA customer use only. There will be no warranty or repair service for USA labeled product from customers outside of the USA. Please keep your purchase receipt and fill out and return your USA warranty card to avoid delays if future warranty or repair service should be needed.
4Likes
