Speed Passion Thread >
Like Tree4Likes
Old 01-27-2014 | 12:13 PM
  #4471
Originally Posted by Nexus
Before anything I would recalibrate your radio to the ESX.
I believe the 7.5 is much more stout than a 9.5. You can get excellent speed out of 9.5 and it is easier to control if you have a heavy throttle finger. If you are smooth on the throttle I would opt for the 7.5.
Thanks Nexus!!
I will try that out and see what happens... Anyway I think the motor is fried... It has something loose inside too :/
lovethebuggy is offline
Old 01-28-2014 | 07:56 AM
  #4472
Originally Posted by AlanHall
is anyone running the blaze stuff in a 4wd truck ?
Hi AlanHall, I'm racing SP Blaze 5700 with a Reventon Pro 1.1 in my TLR SCTE-TEN 2.0. I had Tekin RX8 with a Tekin HD 4600 KV Pro 4 motor.
b4wires is offline
Old 01-28-2014 | 09:07 AM
  #4473
AlanHall's Avatar
how do you like it compared to the other?
AlanHall is offline
Old 01-28-2014 | 10:06 AM
  #4474
I like the SP better. Smooth on the throttle then Tekin. Faster out of the corners.
b4wires is offline
Old 01-28-2014 | 10:17 AM
  #4475
I tried recalibrating the ESC and it is the se... Can't start from still and is running like in 300kv form it is really slow... I guess is blown up... Anyway, I purchased the Reventon R combo with a 7.5t competition motor and just hope it to be here fast!!
Old 01-28-2014 | 10:37 PM
  #4476
AlanHall's Avatar
does it gear much different that a 4pole 4600? would a blaze 4600 compareto a tekin 4600? and would i get a 5700 or 4600 for 4wd short course
AlanHall is offline
Old 01-29-2014 | 07:18 AM
  #4477
I went one tooth lower with the Blaze 5700. Right now I'm geared at 40/13. Tekin 4600 I was at 40/14 with the Tekin setup. My temp with SP ESC and motor is at 108/108.
Temp on the Tekin ESC/motor was at 134/156.
b4wires is offline
Old 01-29-2014 | 09:53 AM
  #4478
C4PT4IN's Avatar
Is it me or did they just rebrand your ESC?
C4PT4IN is offline
Old 01-29-2014 | 12:00 PM
  #4479
MOmo's Avatar
Originally Posted by C4PT4IN
Is it me or did they just rebrand your ESC]
I was thinking the same thing.
still having issues with my citrix club spec.
what's the order when connecting it to the program box and what causes the solid orange wnd blinking red light?
also, when I make changes I can make one adjustment and on my led box, I get dashed lines across the screen. With my S, I get to make other menu selections. Is this bunk?
it was a replacement for the kit durango one.
Momo
MOmo is offline
Old 01-29-2014 | 12:04 PM
  #4480
Pittsdriver's Avatar
I thought the same thing when I saw that. It is obvious the answer is yes.
Pittsdriver is offline
Old 01-29-2014 | 06:41 PM
  #4481
Momo
Momo,
solid orange means you are running a sensorless motor. Is your sensor cable damaged or you running a sensorless motor?
blinking red means low voltage is detected.
Nexus is offline
Old 01-29-2014 | 06:44 PM
  #4482
I just got a Reventon Pro 1.1 and have been reviewing the manual, I don't see anything about which LED lights flash in Blinky Mode. Anyone have any info on it?
Riverbluff is offline
Old 01-29-2014 | 06:55 PM
  #4483
When running stock blinky no timing the red led will blink.
Nexus is offline
Old 01-29-2014 | 07:18 PM
  #4484
Thanks.
Old 01-29-2014 | 10:53 PM
  #4485
MOmo's Avatar
Momo,
I thought so about the red. This was on a charged pack.
ill see if a different cable changes anything. Its a 17.5 trinity.
Momo
MOmo is offline
