Speed Passion Thread >
Like Tree4Likes
Old 11-29-2014 | 07:07 AM
  #5221
Originally Posted by Coopz
Do you need the fan in the Reventon R? Finished a 6m race and the esc was only 35c. Fan is loud and makes the body fitting a bit tricky.
I am running a "R" esc in my 2wd buggy and a V4 8.5 motor with no fan. No issues here.
Raul Garcia is offline
Old 11-29-2014 | 07:27 AM
  #5222
In 2WD and 4WD a fan isn't necessary. The only time I've really even seen our Pros use the fan is outdoors on a hot day in 4WD Modified. Even then it's not all of the time.
Originally Posted by Raul Garcia
Hey guys, I have got to say something. The new V4 motors are awesome. I am running one in my 2wd buggy with a Reventon "R", on Stock 1 profile with a 8.5. It's a bullet! You won't be disappointed.
Nice. They are slowly making their way to racetracks all over. A few guys are running V4s at the US Indoor Championships (onroad :P) this weekend.
Originally Posted by See
Any idea when we will see a V4 17.5?
Originally Posted by Fixmy59bug
I'm waiting for 10.5, 13.5 and 17.5
Might be after holidays. I know they are really trying to get this motor not just on par with others, but better.
Originally Posted by brandon1116
Good luck ever trying to contact technical support!!! After 3 minutes of being on hold it sends you to an answering machine!!! Never in my life of being on hold have I been sent to an answering machine!!! Left them a message to call me back but when will that be??? Whatever happened to staying on hold until you could actually talk to someone "first call first serve style" So pissed with speed passion first time on the track and my motor fries and now I have to leave a message and hope to the rc gods they even return my call!!! By the time they do call back even if they do I will already have ordered a new motor!!! And I tell you this it won't be a speed passion motor!!!!!!
Sorry for your bad experience. Did you go through the RMA process online to file a return/exchange? Email [email protected] and I can try and get you to the right party.
Nexus is offline
Old 11-29-2014 | 11:03 PM
  #5223
Ultraspeed84's Avatar
Who has the v4 in stock in the US? 7.5
Ultraspeed84 is offline
Old 11-30-2014 | 01:13 AM
  #5224
So where can I get a fan for my reventon pro? It gets a lil warm in the wheeler and i'd like to cool it down if possible. Gearing and what not is good its just a high draw situation.
Skeeter36 is offline
Old 11-30-2014 | 04:56 AM
  #5225
Here. Ordered my 6.5 and 8.5 V4's on Mon and got it Fri...would of been thurs if not for holiday.
http://shop.speedpowerrc.com/competition-v4-0/
http://shop.speedpowerrc.com/esc/
kwiksi is offline
Old 11-30-2014 | 09:27 AM
  #5226
How good is speed pasion costumer service?? Pretty sure my motor is fried after two laps of running!!!
Their CS is not great that's for sure. I bought my setups online through FaceBook, SpeedPower is what its called in the US. Did a RMA online and also used their chat. Did get my ESC exchanged but it took a long time. Most all my ESC and Motors are SP so I bought extra as spares if needed. They are cheap enough and it's always a good idea to have a spare setup if you're racing.
evodawg is offline
Old 12-01-2014 | 11:33 AM
  #5227
Are you running outdoors in warm/hot weather? Most guys I have seen and talked to generally will not run a fan in 4WD buggy. You can use the ones sold by Speed Passion. If you are really concerned and want something high powered then maybe checkout the WTF or R1Works brand fans.
Nexus is offline
Old 12-01-2014 | 02:09 PM
  #5228
the incubus's Avatar
I run the Fan on my 410 as temps do rise in that car and I run a 2nd fan under the front drive shaft blowing over the motor, away from my ESC. ESC feels hot at times but has yet to let me down.
the incubus is offline
Old 12-01-2014 | 05:10 PM
  #5229
heinen81's Avatar
So since Speedpower , and god bless them because they are a great supplier, has not restocked their red ring 12.5 rotor in months.... I would like to buy the trinity 12.5 and retrofit it. It looks like 6 mm on pinion side with 2 mm on board side, shimming. Anyone see any problems in doing this?
heinen81 is offline
Old 12-01-2014 | 05:13 PM
  #5230
I ran 4w buggy this weekend with the v4 7.5.. It was so smooth.
SRW141 is offline
Old 12-01-2014 | 05:25 PM
  #5231
MOmo's Avatar
For those NOT having trouble with Brakes, what are you running for EPA?
I ran My Rev R in my Bmax2 MR yesterday and tuned my brake EPA clear down to like 60% just enough to allow some fade, but yet if I Stomp it, I can get the car to pivot. Brake at 100% are too much.
MOmo
MOmo is offline
Old 12-01-2014 | 05:27 PM
  #5232
Maybe this is due to the V4?
Old 12-02-2014 | 05:14 AM
  #5233
heinen81's Avatar
Could be, Raul. I will probably just give the Trinity HT rotor a shot and see if the shimming works. I'm not giving up anything on the top end for straight speed... but through the technical "s" section, I lose 2-3 feet a lap to the D4's with HT rotors. You can definitely see them launch harder in the low end area of the track.
heinen81 is offline
Old 12-02-2014 | 07:08 AM
  #5234
I have found that with blinky firmware. 17.5 with a 12.3 rotor. The brakes are soft. But, when you use a 12.5 rotor with the same settings for brakes. You will do a donuts.
I have never had issues with brakes in any other firmware.
I just mess with throttle % on the radio and then set higher drag brake to get what I want when using a 12.3 rotors.
SRW141 is offline
Old 12-02-2014 | 09:45 AM
  #5235
Would the 17.5 v3 mmm handle 40* esc boost and 5* turbo on a 27/75 gear?
NewbieRacer30 is offline
