Speed Passion Thread >
Like Tree4Likes
Old 11-21-2014 | 05:40 PM
  #5206
Autocratic's Avatar
Originally Posted by PIIHB!
Do I really need that capacitor on my reventon pro?? I run a cap plugged into my rx for my savox servo and just didn't want to be redundant since I run 17.5.
The cap on the ESC is for voltage spikes and to help with punch and heat generated by the ESC. The cap for you receiver is completely different and serves a whole other purpose. You need the cap on the ESC.
Autocratic is offline
Old 11-21-2014 | 06:38 PM
  #5207
PIIHB!'s Avatar
Thanks for the help!
PIIHB! is offline
Old 11-22-2014 | 08:44 PM
  #5208
Just tried out my b44.2 with speed passion 6.5t!! Running turnigy trackstar 120a turbo esc with 19 tooth pinion!! First run going good the car stopped! Took it to the pit and motor was super hot even seen smoke rolling off while the esc was very cool!! Dropped pinion down a couple teeth and let motor cool then put some more laps down!! And instantly motor was too hot to touch!! So my ? Is my motor toast or am I completely over looking something??? 19 tooth should be proper for this since I have done hours worth of homework on everything I equipped in this car!!
brandon1116 is offline
Old 11-22-2014 | 10:57 PM
  #5209
Hi, I just got a speed passion v3 17.5 and put it in my b4.1 2wd buggy... I also run a tekin rs pro esc. I was wondering what timing/boost on the tekin esc should I use with the factory endbell timing on the speed passion motor to produce best results? I know all tracks a different this one is a medium track stock buggy guys running 21-24 sec lap times for reference. Thanks so much in advance. Also gearing right now is 26/72 but have 33/69 on standby
NewbieRacer30 is offline
Old 11-23-2014 | 07:12 AM
  #5210
How good is speed pasion costumer service?? Pretty sure my motor is fried after two laps of running!!!
Old 11-23-2014 | 08:31 AM
  #5211
Anythuing binding in the driveline? Gearing seems right. What kind of settings do you have on speedo? Turbo /boost will raqise temps in motor if not done right.
Sorry about the touble. Link below..best to call.
http://www.speedpassion.net/us/wheretobuy.asp
kwiksi is offline
Old 11-23-2014 | 08:34 AM
  #5212
Might check in Tekin thread...been years since I've ran 17.5 boosted. Anytime you do that you'll want to gear it like a mod.
kwiksi is offline
Old 11-23-2014 | 09:09 PM
  #5213
alright thanks ill try over there. thanks
Old 11-24-2014 | 04:48 AM
  #5214
Hey guys, I have got to say something. The new V4 motors are awesome. I am running one in my 2wd buggy with a Reventon "R", on Stock 1 profile with a 8.5. It's a bullet! You won't be disappointed.
Raul Garcia is offline
Old 11-24-2014 | 12:55 PM
  #5215
See
Any idea when we will see a V4 17.5?
See is offline
Old 11-24-2014 | 01:08 PM
  #5216
R/C Tech Elite Member
I'm waiting for 10.5, 13.5 and 17.5
Fixmy59bug is offline
Old 11-24-2014 | 01:27 PM
  #5217
Good luck ever trying to contact technical support!!! After 3 minutes of being on hold it sends you to an answering machine!!! Never in my life of being on hold have I been sent to an answering machine!!! Left them a message to call me back but when will that be??? Whatever happened to staying on hold until you could actually talk to someone "first call first serve style" So pissed with speed passion first time on the track and my motor fries and now I have to leave a message and hope to the rc gods they even return my call!!! By the time they do call back even if they do I will already have ordered a new motor!!! And I tell you this it won't be a speed passion motor!!!!!!
Old 11-28-2014 | 09:32 PM
  #5218
Coopz's Avatar
Do you need the fan in the Reventon R? Finished a 6m race and the esc was only 35c. Fan is loud and makes the body fitting a bit tricky.
Coopz is offline
Old 11-28-2014 | 11:28 PM
  #5219
See
For stock I do not run the fan on my Reventons but for mod I do. If your temps are ok you should be fine without it.
See is offline
Old 11-29-2014 | 05:24 AM
  #5220
Yes! Just got my 6.5 & 8.5's. They look great and bullet plugs are dialed. I tried other motors for a min, but hated breaking out the solder iron for maint.
Still in testing.
Sorry to hear about your experience. Alot of businesses do this. Hope you didn't just give up after one call/email.
I understand your frustration, but I think anyone here can tell you they've had stuff go bad out the box. I had a LRP speedo, a motor, and Futaba speedo go bad right out package. Had a Hitec charger go bad as well after little use. The speedo was taken care of through Horizon, the motor no luck through LRP. Hitec was out of warr and Futaba took a month to get back in the day. I wouldn't hesitate to use any of these brands now. I use 2 Hitec chargers now.
kwiksi is offline
