Speed Passion Thread >
Like Tree4Likes
Old 01-20-2015 | 02:25 PM
  #5356
jnelson214's Avatar
Originally Posted by jnelson214
I am having an issue with my reverse not working, I made sure the program is set up for reverse. Is it common or possible for the ESC to stop working in a particular direction? FWD works perfect. I am using a GT 2.1
I am still having issue with this... I did recalibrate the esc to rx like suggested and that didnt make a difference. I did change the setting to FWD/REV and the reverse does work but I have NO brakes. When I set it to Fwd/Brk/Rev is when the brake works but no reverse. Is this just how it is or am I missing the obvious? sorry I am rusty!
jnelson214 is offline
Old 01-20-2015 | 03:18 PM
  #5357
303slowdown's Avatar
Have you tried updating the firmware or just reloading it from your computer? There was a guy at my track that his esc had full drag brake but the box said it was at 0 . He reloaded the firmware and it fixed his problem. Try that.
303slowdown is offline
Old 01-20-2015 | 10:05 PM
  #5358
kiwi_tim's Avatar
I brought a new 7.5T v3, when try to run it the esc (LRP) shows sensor fault, if I slowly rotate the shaft by hand the fault clears for 5 magnetic 'clicks' then every 6th click of rotation the sensor connection fault light on the esc reappears, I also have a new 8.5T v3 which works fine, will this be as simple and replacing the sensor unit ( which is cheap, Or am I wasting my time and should just bin it )
kiwi_tim is offline
Old 01-21-2015 | 06:01 AM
  #5359
swap the sensor board from the good motor and see if that works.
Nexus is offline
Old 01-21-2015 | 01:50 PM
  #5360
What's the most current new software for blinky. I plan to switch to blinky for Friday . I see V20 stock but was told there is a new version. And do I Just go to the speed passion website?
Rcfun96 is offline
Old 01-22-2015 | 11:21 AM
  #5361
SamuraiJack's Avatar
Originally Posted by SamuraiJack
Just found this same issue described in the on-road thread. (by rosey1990). Seems like they suspect motor compatibility but nothing really conclusive? I am running Trinity D4 8.5 fwiw.
Should I try cutting 2nd sensor wire?
To close this out: I cut it and it solved the shut down issue with my Trinity D4.
SamuraiJack is offline
Old 01-22-2015 | 11:41 AM
  #5362
heinen81's Avatar
Ahhhh crap. I just looked back on all those incompatibility threads, to make sure the new motor, a Fantom Ion5, would not have an issue with the internal temp sensor on the board. Running a SP 1.1 Pro. Everything pointed to Trinity motors being fine. Seeing as the Fantom is a re-worked D4, I am wondering if i will experience this too.
Samurai - did the issue crop up right away? If so, I guess it will be easier to address.
heinen81 is offline
Old 01-23-2015 | 07:29 AM
  #5363
jnelson214's Avatar
Is there any set up sheets that cover the 2wd sct for the Revention Pro? I did find some from 2011 but they were all the GT2.0 version. I did use them as a guide to start off but would like to see if there are any variations with the new software. thanks
Old 01-23-2015 | 07:49 AM
  #5364
What is the best site to purchase speed passion from? USA buyer.
Ahaynes is offline
Old 01-23-2015 | 07:54 AM
  #5365
Can you post the profile and all the setting your are running?
V21 Stock0 for 17.5. Go to the download section on the main Speed Passion website. If you are racing at RaceEm Raceway a number of guys are using that and running in the A Main consistently.
nice
What class are you running? Mod or stock 2WD SCT?
Generally I suggest going to your local hobby store or track. If you do not have one nearby or don't really visit a track that sells Speed Passion visit WWW.SPEEDPOWERRC.COM. You can always ask your track to contact Speed Passion to setup an account too
Nexus is offline
Old 01-23-2015 | 10:51 AM
  #5366
It did. But this should not be an issue with the 1.1 right?
Old 01-23-2015 | 11:03 AM
  #5367
mvrk28's Avatar
I'm looking at the Reventon Pro 1.1 with a V3 5.5 for a D413, any pointers?
mvrk28 is offline
Old 01-23-2015 | 12:56 PM
  #5368
heinen81's Avatar
Samurai - Good point, I looked back and thought you had a 1.1 as well. Well, I'll find out if it works with a 1.1 this weekend lol.
heinen81 is offline
Old 01-23-2015 | 01:04 PM
  #5369
Nexus what is your suggestion for 2wd sct? Track is a hard clay with decent grip. Fairly tight. I was thinking of the pro 1.1 with a 9.5R. Would you suggest the 9.5 or the 10.5?
Ahaynes is offline
Old 01-24-2015 | 05:52 AM
  #5370
Default Bluetooth module
trying to get this to work again.
it worked perfectly first time and was able to connect no problem, update firmware and settings.
since then, it refuses to connect to the ESC - and therefore can't read the ESC or do anything else.
further, it cannot upgrade firmware - it will start the process, but then show the 0%-100% tatus bar, but never make progress.
I've reset whatever settings can be reset on the module. I've tried with or without the RX connected. I've reset neutral point.
I really want this to work to help dial in the best motor timing I can and so that I can practice with reverse and go back to blinky for racing.
Everything updates fine with a computer and the programming box.
Reventon Pro, Pro 1.1 and S. None of them are working with the BLuetooth anymore.
All firmware on the app have been updated.
eragot is offline
