Speed Passion Thread >
Like Tree4Likes
Old 08-26-2014 | 05:46 AM
  #5071
Originally Posted by srw1969
I am using a Reventon Stock Club ESC/17.5 motor combo. I've tried everything I can think of with the ESC and the LED programming card and have no brakes. I've read every post in this thread and haven't come across a solution.
Has anyone been able to figure this out?
I'll update my own post...
Spoke to Speedpassion direct and the brake issue could be caused by the capacitor hooked up to the ESC being too small for my truck. They suggested trying out the high powered capacitor and that should correct the "no brakes" issue....hopefully!
srw1969 is offline
Old 08-26-2014 | 06:45 AM
  #5072
This might be what you need.
http://shop.speedpowerrc.com/high-po...or-for-2cells/
For anyone with weak brakes. I know the older Reventon 1.0's came with a single cap. The 1.1 now come with this below.
Maybe worth a try.
kwiksi is offline
Old 08-26-2014 | 12:14 PM
  #5073
anythinggas's Avatar
maybe this is a stupid question. i got a speedpassion reventon r from a friend, but he lost the program card; is there any way to program it without the card or will another manufacture such as hobbywing
anythinggas is offline
Old 08-26-2014 | 01:24 PM
  #5074
racer1812's Avatar
Super Moderator
No, you've got to have the programing box in order to do anything besides the basic calibration to the radio. And the factory settings are not ideal for most people so you'll want to get the programing box..
http://shop.speedpowerrc.com/multi-l...rd-version2-0/
this one is much more user friendly though..
http://shop.speedpowerrc.com/revento...-program-card/
racer1812 is offline
Old 08-26-2014 | 04:44 PM
  #5075
If you are going to close to RCPro Saturday. I have extra boxes. Stop bye and I will give you a box.
SRW141 is offline
Old 08-26-2014 | 06:20 PM
  #5076
JDM_DOHC_SiR's Avatar
Exclamation
I currently have the SMC EX-CAP on my 1.0 & 1.1 Revention Pro... and I still have very weak brakes.... highly doubt it will fix your problem if your running the Blinky Software.... but for other programs ... not too sure.. might work.... it's just that their stock Blinky software for brakes leaves a lot to be desired
JDM_DOHC_SiR is offline
Old 08-26-2014 | 06:36 PM
  #5077
sent you a PM
Old 08-27-2014 | 06:18 AM
  #5078
Anybody try the MuchMore blinky software? I don't run blinky so I can't confirm. Maybe there's works better?
http://www.petitrc.com/reglages/spee...eSoftware/eng/
kwiksi is offline
Old 08-27-2014 | 02:04 PM
  #5079
I ran 2w stock last winter and had no issues with lack of brakes. Actually I raced last weekend for the first in 2 years. Blinky TC on-road. And had plenty of braking. Now I use all Speed Passion Product's. There could be an issue with other manufactures motors in combo with SP's firmware. I've never tried to now.
SRW141 is offline
Old 08-28-2014 | 06:56 AM
  #5080
[QUOTE=kwiksi;13495167]Anybody try the MuchMore blinky software? I don't run blinky so I can't confirm. Maybe there's works better?
The Muchmore software says to only use with a Reventon Pro. I'm using the Reventon Stock Club ESC. The new high power capacitor is going to arrive today. I'll post results later tonight or post in the buy/sell forum a ESC for sale...
srw1969 is offline
Old 08-30-2014 | 08:32 PM
  #5081
just got a reventon pro esc for my b5 rear motor. looking forward to trying it out. never had any sp products before. thought i'd take a chance. i got the program card with esc. any ideas on what settings i should start off with. i'll be running outdoors medium bite, tekin 9.5. box stock setup on the b5. thanks
mel_russ615 is offline
Old 08-31-2014 | 08:46 PM
  #5082
drained714's Avatar
does the reventon pro 1.1 ex come with blinky mode pre installed? if not is there one that does?
drained714 is offline
Old 08-31-2014 | 10:17 PM
  #5083
Pauly6401's Avatar
I paired the Reventon Stock Club Race with a Turnigy 21.5 and there are zero brakes. I don't have a program card yet, and it looks like I might not be able to adjust anything without it. I'm having trouble getting it to enter any sort of settings mode to edit the brakes with just the settings button. Is there a trick that the manual doesn't cover? It makes it sound like you can just step through the settings, but mostly it just beeps at me a lot.
Pauly6401 is offline
Old 09-01-2014 | 12:10 AM
  #5084
the incubus's Avatar
The beeping on the ESC means you're in programming mode (if you held down the power button upon powering up) but you can only set your max brake, max throttle and neutral points in this mode without the card. Just make sure your throttle trim is set to absolute neutral before setting all your points. And then make adjustments as needed.
I'm sure someone local to you will have a program box so post in your regional forum and see if anyone offers to help.
the incubus is offline
Old 09-01-2014 | 01:28 AM
  #5085
YOUTUBE watch?v=SOIHGaGedqc
Motor have 3 reactions to full trotle.
1. Normal
2. Mid
3. Slow (smoke starts to appear)
nspavlo is offline
