Speed Passion Thread
#5086
I paired the Reventon Stock Club Race with a Turnigy 21.5 and there are zero brakes. I don't have a program card yet, and it looks like I might not be able to adjust anything without it. I'm having trouble getting it to enter any sort of settings mode to edit the brakes with just the settings button. Is there a trick that the manual doesn't cover? It makes it sound like you can just step through the settings, but mostly it just beeps at me a lot.
Don't waste any more time and money trying to figure it out.
We're switching ESC's come payday.
Sorry for the bad news
#5087
just got a reventon pro esc for my b5 rear motor. looking forward to trying it out. never had any sp products before. thought i'd take a chance. i got the program card with esc. any ideas on what settings i should start off with. i'll be running outdoors medium bite, tekin 9.5. box stock setup on the b5. thanks
#5088
#5089
It's an older Airtronics MX-3 FHSS 2.4 GHz Model. I haven't had any issues with it and 3 or 4 other models of speed controls. I can calibrate the ESC with the radio using the setup button, but I can't modify any of the braking or throttle curve settings like the manual says I should be able to.
#5090
... I have tried it with 2 different KO radio's EX-1 KIY & EX-10 Euros... still no joy.. with "any brakes" in Blinky mode.... but the brakes sure as hell do work well in any other mode...
... I have tried EVERYTHING to get brakes but I'm just chalking it up as .. the programing for blinky mode just sucks for Braking on theses speed controls
... its a shame since they are so smooth an punchy ..
.... Looks like I will just have to try to load the Much More Software for one of my Older Revention Pro's to see if that can work....
#5093
Look what I found fellas.
http://www.speedpassion.net/us/catagory.asp?c=mtr&sc=64
http://www.speedpassion.net/uploadfi...onVersion4.pdf
#5096
Well ive been trying to get an rma from speed passion and there site is trash cause it dose not allow me to submit. Esc sensor board blew up on day 1 of use. All plugged in correct and turned it on and smoke came out and melted the sensor wire. Been trying tobget ahold of them with no response. I deff will not be useing there products anymore
#5097
Hi Everyone,
Got A Reventon S for review I'm doing and I don't know if its the lack of caffine or just me being slow but I can't get it into blinky mode.
I set the timing to 0 but it doesn't blink.... is blinky not availble on the s/ware it comes with out of the box? on the firmware version item on the LCD card it says Mod1 and I can't change that via the card - does this mean i need to doe an ESC Software upgrade??
IS there a link to a simple step by step guide or a sticky on how to do this for someone who has zero sleep?
#5098
Hi Everyone,
#5099
http://www.speedpassion.net/us/wheretobuy.asp
Hi Everyone,
http://www.speedpassion.net/us/produ...SP000010&c=ESC
4Likes
