Speed Passion Thread
#4801
How about a 4 pole 540 can
#4802
Hey there guys, I currently run a Speed Passion GT2.0 Pro in both my 2WD & 4WD off road buggies (1/10th).
I run an 8.5T in the 2WD & a 6.5T in the 4WD.
I have this:
Specification:
Capacity: 1880uf (4*470uf)
Voltage: 16V.
Impedance: 0.002 ohm
Ripple Current Endurance: 24 Amp
Size: 42mm x 17mm x 11mm
Super low impedance.
Low temperature in working state.
Reduces the RF interference to make the RC model more reliable,
Improves the burst power when the motor starts to run.
With its excellent "Ripple Current Endurance", the interference caused by the quick switch on/off of the MOSFET can be observably reduced.
I want to use this:
Specification:
Capacity: 660uf (330uF*2).
Voltage: 16V.
Size: 30mm(L) * 13mm(W) * 13mm(H).
I may have answered my own question - the 4 cap unit has three times the capacity of the 2 cap unit. 1880uf vs. 660uf. But if this is the case how does the Orion and the new Hobbywing 3.0 make such good use of these 2 cap units but the older GT2.0 Pro cannot - or is it that the 4 unit cap just has a lot more capacity built into it and possibly more than it actually needs - over spec'd?
What it comes down to is this - can I use the smaller 2 cap unit in my B5?!
I can live with the 4 cap unit in my 4WD. Although I'd like to swap it out as well.
Can someone help me out with an answer?
Thanks in advance.
D.
I have this:
Specification:
Voltage: 16V.
I want to use this:
Specification:
Voltage: 16V.
Thanks in advance.
D.
#4804
I'm selling my NIB speed passion combo here for cheap http://www.rctech.net/forum/r-c-item...ess-motor.html
#4806
There are a number of setups from our team drivers at http://www.speedpassion.net/us/escsetup.asp
If you see the name Mike Kochanski he is based in the US so his setups might be similar to tracks you run.
I am also hearing alot about savox servos causing brownout due to the spikes.. Is it pretty much assumed that everyone is running a BEC or power glitch capacitor to bypass the ESC??
Just trying to get a concensus on the Reventon/Savox combination...Thinking that might be the culprit..
#4807
Question for the SP experts...is the Reventon R much better then the Stock Club Race?? I have the Stock Club in my T4.2 now and just got a great deal on Reventon R w/ V3 MMM 17.5T Combo...thanks in advance!
#4809
Hey...I got a SP GT 2.0 pro esc for my sct that has a 17.5 motor. Im trying to program it through the setup button but I'm having problems. I've looked in the manual and I keep messing up the calibration. The instructions are confusing on how to get into setup mode...I'm going to get a programming box soon but for now I'm using the setup button.
#4810
#4811
Teamates...... what are you guys using for 4wd sct???? I know we have the Blaze motor wise... but what abt 2 cell capable escs????? Sorry If I missed this discussion earlier.
Thx Guys!!!!
Thx Guys!!!!
#4813
THAT is exactly what I was thinking as well. Just wondered how well it wd handle the larger motor. Thx J!
#4814
If I were to run the class again, I'm not sure I'd run the boost. The 5700 is a beast as it is.
4Likes
