Speed Passion Thread >
Like Tree4Likes
Old 08-28-2012 | 03:55 PM
  #1606
Originally Posted by Solara
Most ppl are running 205g that is will full dynamic timing setting....they don't need boost or turbo for that. You can find alot of setup like that on our website.
I thought 205g was fixed timing advance, ie static, not dynamic?
Dave H is offline
Old 08-29-2012 | 11:48 AM
  #1607
Cain's Avatar
Tech Legend
Originally Posted by hairymuffin
can the gt 2.0pro handle a 550 motor like the tekin pro4 3300?
I run the Pro4 4000kv motor with no issues in an SC104x4 that has the heavier exotek chassis.
software wise, if I recall I am using one of the newer MOD softwares but will be going with the new Stock one since it seems using turbo for more RPM down the straight is common now, and keeps temps down versus going up in pinion size.
Cain is offline
Old 08-29-2012 | 01:24 PM
  #1608
Yes....
Solara is offline
  #1609
Originally Posted by JosephBlack
Thinking about trying Speed Passion for the first time. Maybe put the V3 comp 6.5 in my Dex410.
Good choice?
oh, pairing with a Orion R10pro
Yes, you will like it...
Solara is offline
Old 08-29-2012 | 02:03 PM
  #1610
blade329's Avatar
R/C Tech Elite Member
I recently started running Speed Passion (Silver Arrow V2) in my Losi 8ight. Very impressed with it so far. If it outlasts my RX8 (7 months on avg), then Speed Passion will have a new very loyal customer.
blade329 is offline
Old 08-29-2012 | 11:00 PM
  #1611
hairymuffin's Avatar
thanks...any idea wich software to run?
hairymuffin is offline
Old 08-30-2012 | 09:24 AM
  #1612
Cain's Avatar
Tech Legend
based on what was suggested to me I am going to try the 428 stock one.
However if you are concerned about using a stock software (basically using it to get the supercharger and boost features) I think the 518 or whatever its called one was made to help with temps in 4x4 SCT usage. At least, thats what I was told and I believe that is what is on the ESC right now.
For the group I was running with, I went with a 2 tooth pinion size change (13 - 15T) and temps were about as high as I would want to go on the motor. I am thinking though with the super charger software, that will give me the top end I need but keep temps at a better level by going back down in pinion size.
Cain is offline
Old 08-31-2012 | 08:29 AM
  #1613
1mrdad's Avatar
If there is a throttle delay, 99% of the time is SENSOR issue...either sensor cable is bad or the sensor board inside the motor is damaged...check them out and replace them accordingly.
I have tried 3 different motors, and 3 different sensor cables, 2 different steering servos, and the car still will not go forward from a complete stop. It will reverse but not go forward, and I still have steering. After feathering the trigger for a minute or two it will go forward. The problem is intermittent. When I first turn the car on and place it on the track it is ok. While racing it is ok, but if the car comes to a complete stop, it won't go forward until it sits for a minute or two. I don't have another esc to try. I am using V3.0 120428Stock software, a Futaba 2.4 radio/receiver, Racers Edge Glitch Buster glitch buster, and Revtech motors. Any suggestions?
1mrdad is offline
Old 08-31-2012 | 08:36 AM
  #1614
Cain's Avatar
Tech Legend
have you tried loading in a different software (say 205MOD) and reset everything? IF that works, try loading in 428STOCK again. If that doesn't work, ESC could be bad.
Cain is offline
Old 08-31-2012 | 08:50 AM
  #1615
1mrdad's Avatar
OK. I'll try that. Unfortunately, at practice last night, with no warning, a guy decided to walk out into the middle of the track , just as I started to launch from a triple that has to be taken at full speed. I hit his ankle on landing, and the impact tore off the right front suspension arm, as well as breaking the nose of the chassis. So, it'll be a few days before I can try that.
1mrdad is offline
Old 09-03-2012 | 03:21 PM
  #1616
trickedout's Avatar
Anyone have a reventon wifi module they want to sell?
trickedout is offline
Old 09-03-2012 | 07:44 PM
  #1617
yodace's Avatar
Are the reventon pro's out yet? Where's a good place to get speed passion speedos?
yodace is offline
Old 09-03-2012 | 07:57 PM
  #1618
trickedout's Avatar
No the pro is not out yet. Usually straight from speed passion is the best place..
Old 09-03-2012 | 08:13 PM
  #1619
Cain's Avatar
Tech Legend
sure about that? I see one for sale on ebay.
Cain is offline
Old 09-03-2012 | 09:41 PM
  #1620
trickedout's Avatar
Eh, I'd be cautious about that considering its the only one on eBay and they don't even post a item location...
