Viper RC -
#9136
tony - a55 is latest, greatest
boborc - the caps will help a little - there is a big difference between 2 pole/4 pole. The caps wont make that up completely, but it will help slightly. It really depends on your driving style, track layout, and size. Some places 2 pole can run with 4 pole. Some places - no chance. They are just too different.
Duck - since the Copperhead is not sensored, sometimes after a big tumble it takes 2-3 seconds to figure out the firing pattern to run again. If it is completely shutting down and restarting - takes like 10-15 seconds, might be a loose connection, or amp spike causing low voltage cut off.
#9137
would you recommend the pro 6 or 9. I'm not looking for too much more with the 2 pole and at this particular track it might be the set-up because I can gain a lot in the infield rather than spinning my wheels "pun intended".
#9138
Motor disconnected same. I tore it out of the MIP. Im sending it in connected to each other. It has the extra long wires to reach on the MIP chassis and the SCTE 2.0. I hope it all comes back the same. Sucks it leaves me out for LCRC Halloween. Unless it comes back by friday. Gonna try to borrow a system for this Saturday.
#9139
boborc - normally we use Pro6 in 1/10, Pro9 in 1/8 - although Travis did test with the Pro9 in his 4wd buggy at the Worlds.
spider - hate to see anyone have an issue, quicker we get it we can look at it and return it. Meaning, if you want it back quicker, think about that when you ship it to us. Because sometimes, that is the longest part.
#9140
Is it true that you are not supposed to extend the wires on the capacitors or can you? As everyone knows not much space in a sc10 4x4 with a vtx8 locating the capacitor may be a little complicated for something so simple
#9143
Ok, so our current indoor clay layout has a jump with a short run-up that I cannot clear. This is in Stock (blinky) SC class. There are others that can clear it everytime. I run the VTX10-BE with a Trinity D3.5 motor in my SC10. There are several guys that can clear it but I talked with 2 of them in detail, to try out their gearing and motor timing. Both of the guys actually run Orion R10 Pros but one runs the Fantom version of the D3.5, and the other one runs the D3.5. So the main difference is the ESC. Oddly they are both at opposite ends, One guy runs zero motor timing and a gearing of 75/29 and the other runs full 40* motor timing and gearing of 81/20. They couldn't help me on ESC settings. The guy running the Fantom came over and set my ball diff like his and checked over my basic setup and it was nearly identical to his short of the tires, so I switched to his tires with no improvement. I could not find a combination that worked, the fastest lap times that I was getting were with zero endbell timing and 75/28 gearing. The other difference was that they both run 90C Orion 2s lipos and I run the Nanotech 60c-120c lipos. During practice after racing, I tried combinations of endbell timing and gearing to all extremes with no luck. Even with zero timing and 87/19 I could not make the jump.
I feel that I am maybe missing a setting in the VTX10-BE that is limiting the performance. Here are the settings that I can remember:
Firmware A32
Brake 92% / EXP-2
Drag Brake = 7%
Throttle PWM 9600hz
Throttle Punch 90%
Throttle Curve EXP -3
Deadband Middle
Motor Power = Disabled
MISC
Forward = 100%
Running my current settings, I can get through the infield and down the main straight evenly, but the jump kills me. Any help would be appreciated. I am also looking to replace the motor before the end of 2014/Q1 (officially removed from ROAR).
Firmware A32
Brake 92% / EXP-2
Drag Brake = 7%
Throttle PWM 9600hz
Throttle Punch 90%
Deadband Middle
MISC
Forward = 100%
#9145
A few dumb questions:
Did either of them try your truck? Or have you tried their trucks?
You haven't cooked your motor previously?
Is it wheelspinning at all on the leadup?
I'd also try the batteries as mentioned...
#9147
Is the lights kind of dancing when you try to turn it off?
I noticed that on my VTX8 with my radio if I get some kind of drift at neutral, I can't shut it off. Its like it thinks its getting a signal from the radio. You can try giving either a bit of throttle or brake to get it to "neutral" and then shutoff. Or, just pull the plug is what I did.
#9148
I did get the motor hot one night when we had open class so I turned on boost for one race. It was 95 degrees in the building, my motor hit 175* after the first qual, so I turned off boost. Normally it is in the 150's after each round. I don't think this cooked it though.
I was struggling with wheelspin a little and switching to the other tires fixed that but not enough to make the jump.
Next time I will ask to drive their trucks or borrow batteries. I hate doing that but it is frustrating trying extreme's of endbell timing and gearing with no change in performance. Maybe the motor is dead on the lowend.
#9149
90C is a pretty big difference from 60C. I would be interested to hear if you were able to clear the double with one of their 90C packs. I would also agree that you should let one of them wheel your truck and see if they can clear the jump. Maybe they have a little different line that lets them carry more speed to the jump.
If you are having problems turning off the ESC try turning your radio off first.
#9150
So my ESC settings seem fine then? and it is probably battery or motor. Maybe I will escalate my time table of getting a new motor then.
4Likes
