Like Tree352Likes
NOVAROSSI Engine thread....
Old 07-02-2012 | 05:48 PM
  #3316
Smile toro nero
hi iv been looking for parts for a toro nero engine and i cant find them anywere. and is there a engine made by novarossi that has compatible parts with the toro nero. mainly looking for a piston and sleeve.
tippy606 is offline
Old 07-02-2012 | 05:57 PM
  #3317
kgombe's Avatar
Check Houston engine services
Or
http://www.ebay.com/itm/Novarossi-To...item43aa66146c
kgombe is offline
Old 07-02-2012 | 06:16 PM
  #3318
i was hopping to jsut be able to buy piston because im a bit low on money
tippy606 is offline
Old 07-02-2012 | 06:23 PM
  #3319
houston's Avatar
That wont happen anywhere , guaranteed
They are matched as a precision matched set at the factory
You have a pm, private message in your upper right hand corner
houston is offline
Old 07-02-2012 | 09:06 PM
  #3320
Som3R3tard's Avatar
Originally Posted by Som3R3tard
Hey guys got a 21+7fms with a dynamite 053mr. Ambient air temp was 105. Motor came off track at 295. Seems like it didn't have that much top end speed. I couldn't keep up with the ninja or bullet motors on the straights. What should I do? Motor might have 2gallons on it. Seems to still have compression even when hot. Thanks in advance
Just checked clutch bell and spur gear. 13/50 is the combo currently in the truggy. Venturi is 6.5 is that about right? M2c 4 shoe with 1.05 springs. the high speed is about 1 and a half turns from flush right now. If i richen up the high side will i will need to lean the low side ?
Som3R3tard is offline
Old 07-02-2012 | 11:51 PM
  #3321
merdith6's Avatar
Default Hey
Most likely the low end will need to be leaned slightly. The low end is very sensitive and needs small adustments. but make sure the idle gap is not too big first. Drop the idle a little, then lean the bottom a little, then put the top flush. What brand truggy? Going by gearing depends on the truck, but most likely the gearing is fine. The clutch may be fine, but may not be. I would use lighter springs. If I remember correctly the .9's were the ticket with the M2c 4 shoe, the yellow ones anyway.
When the top is lean the bottom ends up slightly rich and the engine has trouble clearing out properly, and runs down the strait on the build up of fuel and goes lean when that runs out just when it needs more. I hope this helps.
merdith6 is offline
Old 07-03-2012 | 02:46 AM
  #3322
xax
I am looking at the Bonito and the BTTS.Anyone can tell me what the difference and which one should i get for my MBX6R.Thanks
xax is offline
Old 07-03-2012 | 03:06 AM
  #3323
I have run with both engines and actually with the same car.
BTTS:
+ price
+ quality
+ tuning quite easy
+ very long using time this engine can takes so many gallon through..
- lack of high power
Bonito
- price
- reliabilty not 100% people have some tuning problems when weather is cooler
+ quality
+ power
But the choosing depends a lot what kind of racer you are and what kind of tracks you are running. I think in Euro style tracks Bonito is the right choose but in USA style...hmm
RookieForever is offline
Old 07-03-2012 | 04:53 AM
  #3324
aussies1129's Avatar
I currently run the btt in my mbx6 and its got enough power right thru the rev range, its modified and with a 7mm carb insert it holds its own against any os speed
I feel the btt is a bit more user friendly as the bonito in a buggy is brutal.
aussies1129 is offline
Old 07-03-2012 | 10:12 AM
  #3325
I haven't done a controlled test yet, but I'm curious. What sort of runtime are people expecting from the Plus-4C Team w/9901? I think I can do between 8 and 9 minutes from fill up to flame out. This being with the exhaust gas cooler, 6mm insert, C6TGC plugs in an MBX6R.
Semple is offline
Old 07-03-2012 | 11:56 AM
  #3326
John I would think you should be able to get 10 minutes. You will have to do some testing.
Chris Reilly is offline
Old 07-03-2012 | 03:06 PM
  #3327
ABN Hoosier's Avatar
Quick question...
I just bought this fuel filter and it didn't come with instructions specifying the In/Out fuel flow. Took a picture. Any suggestions, it's 50/50.... There is a little hole on the right/center of the brass filter housing. Maybe it is the In?
Schumacher Alloy Sintered Fuel Filter (Purple)
[SCHU2851]
ABN Hoosier is offline
Old 07-03-2012 | 03:25 PM
  #3328
houston's Avatar
always use the cavity side as the inlet
left to right in the pic
houston is offline
Old 07-03-2012 | 03:28 PM
  #3329
thank you Sir
Old 07-03-2012 | 03:29 PM
  #3330
houston's Avatar
Originally Posted by ABN Hoosier
thank you Sir
sir? come on now sheesh , just a racer like you brotha
i am here to help you guys if you need it
houston is offline
