Like Tree352Likes
NOVAROSSI Engine thread....
Old 06-10-2012 | 06:30 AM
  #3091
Wheelie master's Avatar
Originally Posted by merdith6
I don't understand. are you billy Easton, or is it his engine or what? oh well. I would say drop the shimming a little bit. I run my plus-4's and p5's at .70 with 25%. what pipe? etc.. are you running. and leaning out the top end only makes an engine faster up unitl a point when it doesnt have enough fuel to burn.
Like above mentioned try the 7.5 restrictor, and put the top and bottom flush and retune. try another pipe, I bet you have the 9901 on it.
no obv im not him but i had easton try to tune the engine and still no luck.. started the needles at flush.. besides its not my first engine.. my bonito runs awesome and i tuned that..
i will try the bigger restrictor.. and yes the 9901.. what pipe do you suggest?
why is it my budddy has the same engine with the same pipe restrictor and all other things the same and his screams?
Wheelie master is offline
Old 06-10-2012 | 06:56 AM
  #3092
Maximo's Avatar
same fuels ?
you likely have some underlying mechanical issue that is being overlooked.........feel free to contact me and I will try to help you find it
Maximo is offline
Old 06-10-2012 | 09:15 AM
  #3093
air8's Avatar
Also is the amount of fuel through the engines the same? Noticed the BTT doesn't "wake up" for nearly two gallons. Then it starts really pulling on top.
I thought same thing of mine and one I broke in for a friend, we needed them modded to get some power. But like I said, they just woke up and doing good now.
air8 is offline
Old 06-10-2012 | 11:29 PM
  #3094
Best way to measure the .6mm idle gap? Can't seem to find anything .6mm :/...any idea's?? Thanks
nrm1977 is offline
Old 06-10-2012 | 11:37 PM
  #3095
shanef's Avatar
Some welding wire does the trick
shanef is offline
Old 06-11-2012 | 12:22 AM
  #3096
Can someone please tell me the part # or link on Amain to the Novarossi ceramic bearings for the Bonito? My paper that came with it says 16004 but that does not pull up on Amain, yet other part #'s do. Also this paper says nothing about the size of the bearings. I would like to buy a front and rear replacement.
Vortexted is offline
Old 06-11-2012 | 12:40 AM
  #3097
houston's Avatar
rear 14.5x26x6x6.3mm
front is part #17011 or 7x19x6x6.3mm
houston is offline
Old 06-11-2012 | 03:26 AM
  #3098
shimano's Avatar
Default Wake up
Can ne one tell me when the Roma really wakes up. Most other novarossi's seam to be around two gallons. Is this the same for the Roma's.
shimano is offline
Old 06-11-2012 | 06:27 AM
  #3099
Sprinkler's Avatar
I switched from Sidewinder Stryke fuel to Byrons this weekend and the difference in my BTT is night and day. Still not like it should be on top, but I don't have 2 gallons through it yet either.
Neal was 100% correct on the fuel. I was just to hard headed to change before.
Sprinkler is offline
Old 06-11-2012 | 08:39 AM
  #3100
beidle99's Avatar
Best guess would be about 2 gallons.
beidle99 is offline
Old 06-11-2012 | 05:59 PM
  #3101
aussies1129's Avatar
easiest thing to use and alot of guys would have them in there tool box
a small cable tie! check it with calipers then you can even trim the end with some side cutters and it will fit in there perfect without any damage
aussies1129 is offline
Old 06-11-2012 | 06:43 PM
  #3102
rider313's Avatar
I found one of my GF's sewing pins. Found a pin at .7mm and .55mm. I put a tab with each mesurement.
rider313 is offline
Old 06-11-2012 | 07:56 PM
  #3103
Default Shim
Just got a Tuned BTT4 and they say it is shimmed for 25%. Does it need reshimmed for 30%? Recommended amount of shim thickness?
TIA!!
RandyJones is offline
Old 06-11-2012 | 08:23 PM
  #3104
beidle99's Avatar
TIA!!
It will run fine on the 30% with stock shims. Just break in with Byron's 30/11 minimum or add some lube booster if less then 11% oil. Castor oil is good.
beidle99 is offline
Old 06-11-2012 | 09:23 PM
  #3105
When you guys are setting the idle gap with the cable ties or sewing needles are you leaving the carb insert in or out ?
evolution03 is offline
