Like Tree352Likes
NOVAROSSI Engine thread....
Old 09-09-2012 | 11:49 AM
  #3841
merdith6's Avatar
Default well
Originally Posted by dia
Hi guys. Can you please help out!! A back plate screw on my engine was decapitated.... and there is no way to take it out. So I'm looking for another crankase at a reosonable price. I found one from a bonito 21-7xlb/a(part # 09029tn11) where as the toro neros is 09029tn. Does anyone know if it will be ok? Will my engine seal if I use lucky7 sealant and 3 out of 4 screws?
Any ideas? Thank you for in advance for any replies provided.
I had that happen once and if you try to get it out it could cause more problems. I say seal it up and run it. It worked for me.
merdith6 is offline
Old 09-09-2012 | 01:04 PM
  #3842
houston's Avatar
i have a couple toro nero cases , i will make you a pretty good deal , just lmk
houston is offline
Old 09-11-2012 | 06:53 AM
  #3843
jnorwood_losi's Avatar
Default Bearing question
I am putting new bearings in my Bonito, the new 17011 Nova bearing I have has a clear looking seal on the side that would face the inside of the engine, but the one I pulled out does not have this. Is it something I need to take out????
jnorwood_losi is offline
Old 09-11-2012 | 04:01 PM
  #3844
Anyone know the answer?
Old 09-11-2012 | 04:17 PM
  #3845
guys been looking at the novas had a question is there much difference between the BTT vs the +4 team?
transplantlife is offline
Old 09-11-2012 | 06:05 PM
  #3846
beidle99's Avatar
I have a Btt. in running, the Btt will have a slight edge in top speed while the team has a little more bottom. Run either with a 2058, 9901, or 2096. The 2096 will give you great bottom end, top end and run time My btt with the 2096 pipe feels like an electric without the crazy wheel spin. It just squats and goes. Some guys have been talking about a 2032 pipe I believe, but they are hard to come by.
beidle99 is offline
Old 09-11-2012 | 06:08 PM
  #3847
beidle99's Avatar
I would leave the seal on, but I know the bearing that came in my plus 4 (not a 17011 as advertised) had that seal and the 17011 I put in did not have the seal. Maybe ask over on the HES thread. Monty knows the bearings pretty good.
beidle99 is offline
Old 09-11-2012 | 06:33 PM
  #3848
None of them are online, it seems weird though. I triple checked the NOVAROSSI and its a 17011. The one that came out SHOULD be a 17011...I am about to put the bearings in now, I keep leaning towards pulling this seal on the inside, as it would lube better...i dunno
Old 09-11-2012 | 06:46 PM
  #3849
rider313's Avatar
I would Leave it on.
rider313 is offline
Old 09-11-2012 | 07:25 PM
  #3850
houston's Avatar
Thats not a "seal" , its the ball cage
houston is offline
Old 09-11-2012 | 08:21 PM
  #3851
Ok, leave it on or pull it out? Thanks Monty
Old 09-11-2012 | 09:26 PM
  #3852
hambone's Avatar
It's what keeps the balls in place. If you pull it out the bearing will fall apart.
hambone is offline
Old 09-11-2012 | 09:40 PM
  #3853
Thanks Rob I left it in and its back together, I dont get why the one that came out did not have it and the new one did...while the other guy that replied earlier said his was vice versa and his new one did not have it....I thought it was all the 17011
Ahh well.
YOU GOING TO LCRC SATURDAY???
Old 09-11-2012 | 09:45 PM
  #3854
hambone's Avatar
I just got back from LCRC, lol. I'll probably be there sat.
hambone is offline
Old 09-11-2012 | 10:36 PM
  #3855
Guillermito's Avatar
Hello, someone tested the engines "Pre-Run"? How many tanks need to be ready for a race?
Thanks. Best Regards.
Guillermito is offline
