Like Tree352Likes
NOVAROSSI Engine thread....
Old 04-02-2012 | 10:18 PM
  #2416
p@p@nut's Avatar
Originally Posted by Lille-bror
Too rich LSN
Too rich HSN
Too cold plug
Too low idlespeed
Overfilled tank
Too cold plug
Too cold plug
What plug, fuel and pipe are you running?
O.S. P3, Mecca 30%, Nova 9901
p@p@nut is offline
Old 04-02-2012 | 10:44 PM
  #2417
PERROTTO's Avatar
Probably a mixture of your tune and plug. Use nova plugs. C5tgc (for cooler temps) or c6tgc (for hot ambient temps). Change plug and lean out bottom end. Tune top end for good temps. This should set you on the right path.
PERROTTO is offline
Old 04-03-2012 | 10:52 AM
  #2418
Lille-bror's Avatar
+1
In Denmark the BTT guys runs c6tgc with 25% nitro. Only #5 in cold temperatures. P3 in such an engine with 30% nitro sounds wrong.
Lille-bror is offline
Old 04-03-2012 | 02:14 PM
  #2419
PERROTTO's Avatar
+1
Lol...P3 plug in a nova engine just sounds wrong. Plus I don't think the taper is the same.
PERROTTO is offline
Old 04-03-2012 | 04:40 PM
  #2420
megasaxon's Avatar
yea the taper is different on OS plugs vs Novas, run a Nova plug in a Nova engine and you shouldnt have any problems. Lots of guys like to run ODonnell plugs because they are cheap, but my Nova plugs always last way longer than any odonnells, so the value is the same or better on the Novas IMO
megasaxon is offline
Old 04-03-2012 | 06:08 PM
  #2421
houston's Avatar
Originally Posted by megasaxon
yea the taper is different on OS plugs vs Novas, run a Nova plug in a Nova engine and you should have any problems. Lots of guys like to run ODonnell plugs because they are cheap, but my Nova plugs always last way longer than any odonnells, so the value is the same or better on the Novas IMO
true dat
houston is offline
Old 04-04-2012 | 01:32 AM
  #2422
Nitro Tiger's Avatar
Has anyone tried the optional carby #24065, if so what sort of fuel consumption gains if any?
Nitro Tiger is offline
Old 04-04-2012 | 10:36 AM
  #2423
Russ G.'s Avatar
I'm using a Nova BTTA on a Mugen MBX6. Which Mugen header should I use for a med lenth track? Which one is equal to the 41021? I have both the short and long Mugen headers. Thanks
Russ G. is offline
Old 04-04-2012 | 11:27 AM
  #2424
megasaxon's Avatar
the 41029 is the header you want, tight bent short header
Old 04-04-2012 | 08:57 PM
  #2425
morocho1979's Avatar
hi i want buy a p3xs but is standard plug so i need turbo what part i need to buy to convert to turbo plug and how many shim i need thx
morocho1979 is offline
Old 04-04-2012 | 08:59 PM
  #2426
megasaxon's Avatar
same shims, 28002 head button
Old 04-05-2012 | 04:32 AM
  #2427
chicky03's Avatar
By the time you do that you might as well buy a p5. This was you get the better rod and more power.
chicky03 is offline
Old 04-05-2012 | 08:11 AM
  #2428
merdith6's Avatar
Default Turbo plugs
I was looking at the Nova website and realized that the c7 plug is really for hot weather.
http://www.novarossi.it/eng/products...hp?plug=ctuoff
merdith6 is offline
Old 04-05-2012 | 09:12 AM
  #2429
Thz for the advise
Old 04-05-2012 | 06:30 PM
  #2430
TommyBlazin's Avatar
yes, and not even that hot to begin with anything over 77 deg?? interesting find there..
TommyBlazin is offline
