Like Tree352Likes
NOVAROSSI Engine thread....
Old 03-31-2012 | 04:40 PM
  #2401
Diff Balls's Avatar
Originally Posted by FUSIONX AUS/NZ
Are you dropping the idle gap when you lean it out? Sounds to me like its too big
Dave
I'll check that....any other suggestions anyone?
Diff Balls is offline
Old 04-01-2012 | 02:03 AM
  #2402
Lille-bror's Avatar
Originally Posted by Diff Balls
Hey guys, I need some input.....I am having a bit of problems with the idle on a 21-4BTT. It only has a gallon, maybe a bit less on it. The idle is rich and when I lean it out, it goes from rich to pinging. I can't get it just right. I have a 21-4C Team, and I can get it perfect.
I have replaced the glow plug and went that route....I don't think that is the issue.
Any ideas? Do i just need to run it rich and let it break in more maybe?
Hi.
Maybe its the combustion chamber. I had an issue with a Plus4 with the same "lean" idle sound. Monty suggested me to change the combustion chamber, and that was the fault.
What plug, pipe, header, fule etc are you running?
Lille-bror is offline
Old 04-01-2012 | 06:21 AM
  #2403
FUSIONX AUS/NZ's Avatar
Originally Posted by Lille-bror
Hi.
Do you know what was wrong/ what happened to your combustion Chamber?
Dave
FUSIONX AUS/NZ is offline
Old 04-01-2012 | 07:53 AM
  #2404
Lille-bror's Avatar
Dave
I couldn't see any error on the chamber, but you can read this:
http://www.rctech.net/forum/10483754-post2357.html
Old 04-01-2012 | 12:57 PM
  #2405
TommyBlazin's Avatar
anyone have any input on the new .25 truggy roma motor/ building a truggy this week and looking for power, starters going to be the bonito tuned/pre-run..but that roma lookin serious? thanks sorry if answered/asked, just looking for most recent update if possible..
TommyBlazin is offline
Old 04-01-2012 | 01:03 PM
  #2406
Kurt04's Avatar
Originally Posted by houston
you mean is the sleeve the same and everything is different ?
its alllllllll novarossi man , lmk if you need anything
decent pipeset on that engine for a truck
clutch? what kinda car you running ? i have been very happy with the buku power clutch lately but am also a big fan of the werks clutch system
Well I got the motor in the truck but it won't run well. Idle is really inconsisitant, sometimes its high, sometimes its low without moving the idle screw, it occasionally surges and dies. If I can get it to stay running any length of time and wind it up it will die on the top end.
Kurt04 is offline
Old 04-01-2012 | 02:55 PM
  #2407
houston's Avatar
There could be alot of things goings on there,
houston is offline
Old 04-01-2012 | 05:45 PM
  #2408
Kurt04's Avatar
Where should I start?
Kurt04 is offline
Old 04-01-2012 | 06:47 PM
  #2409
houston's Avatar
sounds like inconsistent fuel pressure to me
front bearing leaking?
pressure line pinhole?
gummed up carburetor?
first things i would check
does a different engine do the same thing in that car?
houston is offline
Old 04-02-2012 | 05:53 AM
  #2410
Default nova p5xlt
I just got my P5XLT in the mail and I am going to try to get at the least a gallon through it today after I find some fuel ( everyone is out of stock ).
One of the things I've noticed is that there is NO head shims in box ! I haven't taken the head off yet but am assuming there already installed.
Is there any recommendations for running Byron's 30% / OD 97t / platinum 086 pipe /,,,,,,,,,,,,, head shims ?
I read somewhere along these 100pgs. that it was a good idea to flush the engine out with fuel ? or after run oil ? before first start up !
Any advice on this adventure would be appreciated.
RevoUsa is offline
Old 04-02-2012 | 07:21 AM
  #2411
p@p@nut's Avatar
How do i prevent an enigne flameout after a fuel stop? I had this happen to me a couple of times during heats. Using a 21-4T.
p@p@nut is offline
Old 04-02-2012 | 08:08 AM
  #2412
beidle99's Avatar
Originally Posted by psr
hey guys i dont have a issue but a questern i have two btta motors one i brought a few months ago and one i broughts this week for a big race they are both identical part numbers but the older one has a nova branded bearing and the other has some random bearing the one that can be view from out side the engine
is this normal alos could this be a fix for the dodgy nova bearing issue ?
Novarossi, changed the Btta front bearing to a 17004 (i think) instead of the 17011. Monty said all the recent Btta's came with this new bearing. It is the same bearing that the P5 now comes with. Its not a bad bearing and was told it will last a while, just not as long as the 17011 that the motor used to come with. I have a 17011 that is going to go in when the time comes.
beidle99 is offline
Old 04-02-2012 | 08:48 AM
  #2413
Jason Pelletier's Avatar
Use Novarossi plugs. The OD's aren't as good.
Jason Pelletier is offline
Old 04-02-2012 | 08:51 AM
  #2414
phaqu22's Avatar
Try not to pit on a completely empty tank is the best thing to try.
phaqu22 is offline
Old 04-02-2012 | 12:00 PM
  #2415
Lille-bror's Avatar
Too rich LSN
Too rich HSN
Too cold plug
Too low idlespeed
Overfilled tank
Too cold plug
Too cold plug
What plug, fuel and pipe are you running?
