Serpent 710
#1066
All I can say is that after a couple of years running on a very tight track, My setup is basically "exactly" what IntialD was saying.
I put close to 2.5 to 3 Deg of rear toe which in someways allows the car to turn in quicker in both directions do to the amount of corners involved on the track.
Secondly, I also place the caster as stated by "D" for what appears to be a quicker response.
Third, I'm sure someone here has posted or seen the trick with removing approimately 3mm off the front end for a shorter wheelbase.
Lastly, I also do not run sway bars front or rear and the car handles like a gem , letting the shocks do all the work.
Right or wrong in theory it works very well at our track.
When we go to the bigger tracks in California, and Vegas it's a whole different story and the Car is completely different.
Just my two cents, and yes thats probably all it's worth LOL !!!
#1067
Originally posted by InitialD
I find that if you set the front AND rear trackwidth to close or less than 200 mm, you'll get a lot of turn in. Mine is set 199 mm front and 198 mm rear. The 705 will have a wide rear trackwidth (over 200 mm) when you use a camber more than -2 if I'm not mistaken. I believe most of the time, we need more camber in the rear like -3 or -4. I solved this by cutting the rear upper arms like I have shown earlier in the thread to get the rear trackwidth to below 200 mm and still use -4 for camber.
http://www.mytsn.com/products/desc.asp?prid=2910
#1068
Hey,
The new RC mag RC Driver has a full page 710 ad in their January 2004 issue, P 63. All orange and fancy. Nice ad, and this new mag looks really promising. Lot's of useful articles, not like the "other" mag beginning with RC, ending with CA...
We truly live in the best of times.
#1070
Originally posted by JA5ON
u can oso try using smaller rear wheeladapters
But like what Goldfinger mentioned, the wheels will rub on the floating rear mount adaptor which I also use on my TC setup. I believe when I use a 2 degree offset wheel in the rear, somehow it clears up (touches only little when cornering). I need to use the 8 mm adaptors, 2 degree offset wheels with -4 camber and the trackwidth will still be under 200 mm. That's what I use on my Impulse PRO which I have not modified the rear upper arms.
On my 705 with the modded upper rear arms, I use the stock 11 mm aluminum wheel hex adaptor, 0 offset wheels, -4 camber and still under 200 mm (198 mm exactly).
#1071
Pics attached below are more clear. Taken from the rcmodel website.
#1072
MORE STEERING
Sometimes if the car feels good and well balanced in and out of the corners try narrowing the front end to 196 or 194. it will gain lots of steering. This is a trick Lou Pryzbala tought me on the impact. It works when all else fails. you will be amazed what a few MM narrower on the front does for steering and it won't upset the chassis like you would think.
I remember watching Brian Berry narrowing the arms on his Veteq with a dremel where the pivot balls thread in for the same reason.
#1073
Thank a lot for sharing with me (us) serpentracer1.
I really appreciate your valuable input.
About smaller rear toe-in, i do agree with you.
This is 1st lesson from mistake Ive learned
. Before... I thought that more toe in(rear) will stabilised the car when out corner but result was worse. Then try the 1.5 deg. it was like "bang" the rear wheel is able to hold up the line.
As for more caster will help car turns better in sharp corners, I think Im experiencing the same way with "D". Less caster is more required....
. Before... I thought that more toe in(rear) will stabilised the car when out corner but result was worse. Then try the 1.5 deg. it was like "bang" the rear wheel is able to hold up the line.As for more caster will help car turns better in sharp corners, I think Im experiencing the same way with "D". Less caster is more required....
#1074
Originally posted by Motorman
MORE STEERING
MORE STEERING
I think one of the single most important setting that made a difference on the 705 is the trackwidth. I try to run as narrow as I can now and the car handles like a dream.
#1076
Originally posted by markp27
Yep, slow is good!
Which pivot balls are you using with your FC blocks? You can definately get the width down to at least 200mm with the pivot balls for the FC blocks - if I remember rightly they have to be turned in pretty much the whole way.
The wheels are fragile - which ones are you using? The dished wheels are stronger, so it may be worth getting some of those.
Cheers, Mark.
Yep, slow is good!
Cheers, Mark.
I f*cked my stock wheels after the first 3 minutes, and managed to f*cked up the mugen fast disk wheels in the next 5 minutes.
I still have a set of brand new jaco wheels, but I am afraid to use them as I might mess it up again in 8 minutes! hahahah
I think from now on, I'll stick with one brand and one type of wheels, so if I mess a front left, I won't have to change the PAIR! =)
#1078
From the way I read serpentracer1's setting, he needed more on power steering on the track he runs as obviously from his front overdrive, stiffer rear sway bar and less rear to in.
More rear toe-in will not give you on power steering. Off power steering and braking would be better with more rear toe-in.
#1080
Originally posted by paulfitipauldi
My LHS here in Puerto Rico is offering me the 710 at $389.95, I think is a really great price for an intruduction Item!!,,
Ciao!
Ciao!
