Serpent 710
Old 09-23-2004 | 04:05 AM
  #16066
Hi,
Cool ! I notice the 9606 vented disc is thicker than the 801345 and also with a slightly bigger diameter.
That's because it's originaly disigned for the 1/8 scaled car's
I have tested them but like I said before, with the weather conditions here, and the race-brakepabs, you don't get the heat in those pads.
Tempratures around 30/34 degrees C should be no problem with the 9606.
Do you use the race-brake pads (#9607)?
I really recommend those.
They give a good consistant braking, so that change of brake setup during the race won't happen again.
Thomas
840918001 is offline
Old 09-23-2004 | 04:34 AM
  #16067
markp27's Avatar
Default Re: Re: Re: Re:
Originally posted by InitialD
Over here, weather is hot all throughout the year. Normal temperatures are 30 to 34 degree Celsius.
markp27 is offline
Old 09-23-2004 | 05:06 AM
  #16068
sn4il's Avatar
Here is my new baby
Im getting servos today. I have Magnum 3PK. Which servos should i get??
Also which fuel should i use to break-in my engine? Its Novarossi TSR12S5S modified by Jim Hottinger.
Max
sn4il is offline
Old 09-23-2004 | 05:10 AM
  #16069
markp27's Avatar
Originally posted by sn4il
Here is my new baby
Max
Very nice!!
There is a wide choice of servos you could get. Some of the best are the Futaba 9550 they are small and light and provide more than enough torque for the 710.
Fuel is a different question, but use the fuel which you are going to be racing with. Important is, though: what % Nitro do the guys run at your track. Here in Europe there is a limit of 16%, but you may not have this.
There are a good many fuel manufacturers who make good fuel, Tornado and Runner Time are just two of these.
Cheers, Mark.
markp27 is offline
Old 09-23-2004 | 05:15 AM
  #16070
Default Nice ride!
Hi sn4il,
You got a very nice ride!
I would go for the same brand as the radio is.
So in your case I would get Futaba servo's.
If you had a Ko I would get Ko servo's.
I have no experience with the Futaba servo's but I do know that quality is among the best.
If you use Ko Propo, Sanwa/ Airtronics or Futaba you can't go wrong.
Bye Thomas.
Old 09-23-2004 | 05:32 AM
  #16071
Sow&Steady's Avatar
Onkel Sow, it looks like your clutch is slipping excessively. I once set my clutch that way and after one session of playing an hour or so, I could see that the clutch shoes wear a lot. When I set it correctly, my clutch shoes still remain the same (no excessive wear) except some glazing on the shoe surface.
Perhaps you like it that way because of the driving style but I guess that's the downside. Some people let it engage aggressively and like them that way. Maybe harder to drive even. If you set it to engage correct, you will not have the clutch wear out.
Well, its difficult to describe how I like to set my clutch. Maybe when Mark is here he can see how I set it.
As for dimensions, it is usually 0.5mm gap with maybe 0.1mm end play. The spring maybe set to between 0.5-1mm from the end of the retaining nut.
Feels good, quick and I'd be surprised if its slipping. The driving style ... well, I'm an analogue racer so yes, there are times I'm only applying half throttle.
In the end though I can't accept that clutch shoes do not wear. This system is friction based so ....
Sow&Steady is offline
Old 09-23-2004 | 05:34 AM
  #16072
Sow&Steady's Avatar
Ah... Uncle Crash can sometimes work magic.
Yeah, how not to when you open the car up to small bits and pieces EVERY week and clean almost ALL car parts with soap and lube all the bearings before every weekend run !
I thought doing that once every three months was bad enough and he does this every week?
Respect!
Old 09-23-2004 | 05:36 AM
  #16073
Sow&Steady's Avatar
His car is so clean and smooth. Under the chassis of his 710, you could literally stick your tongue on it. It's so squeaky clean !
Mark, sounds like he'll make a good mechanic for us!
D, ask him if he'll come to the WinterNats!
Old 09-23-2004 | 05:37 AM
  #16074
Sow&Steady's Avatar
Originally posted by markp27
Probably Sow will brake it for me in a couple of weeks
Old 09-23-2004 | 06:05 AM
  #16075
markp27's Avatar
And Sow, he can also do some bodyshells for us
markp27 is offline
Old 09-23-2004 | 06:06 AM
  #16076
markp27's Avatar
Good idea, Sow - we can compare how we've built the clutches
markp27 is offline
Old 09-23-2004 | 06:41 AM
  #16077
Sow&Steady's Avatar
Yes, he can buy them where he is (cheaper) and then bring them with him all ready painted!
  #16078
Sow&Steady's Avatar
Definitely!
Old 09-23-2004 | 06:54 AM
  #16079
markp27's Avatar
Excellent idea! Mybe he can service our cars whilst we drink some cocktails? Then it is agreed! D, get Crashed to buy his tickets
markp27 is offline
Old 09-23-2004 | 07:03 AM
  #16080
sn4il's Avatar
For a newbie like me.... should i install front shaft lock?
I had it from optional package which i bought with serpent.
Max
sn4il is offline
