Old 10-14-2004, 08:41 AM   #17566
packetdreamer's Avatar
Send a message via AIM to packetdreamer
Originally posted by KevinS
You may want to get the rear shock support (808138) too, since it's not included. With the pin provided with the bodymount set it keeps the bodymount centered. (see attached pic in my post below)
without it, does the body move from side to side a lot?
packetdreamer is offline   Reply With Quote
Old 10-14-2004, 08:44 AM   #17567
Sow&Steady's Avatar
Originally posted by packetdreamer
what will the belts do for me? which drive pully? the one on the rear shaft that goes to the rear diff/solid axle?
If you change over to a solid rear, a stronger belt is preferred. Not mandatory but preferred ... well, you know how much work in involved in changing the rear belt of a 705 is right? The solid axle does not bleed much power to waste and thus puts a lot strain on the whole drive train if you're using a powerful engine.
Yes, the pully on the main shaft that goes to the rear diff/solid axle.
Increases the internal ratio slightly from 2.0 to 2.09 and if you can find a 14t first gear pinion then you'll be flying!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 10-14-2004, 08:48 AM   #17568
yea i know about the 705, so the advice is good. i thought i would get this impulse pro and just have it as a side kit or something my son might be able to run a little... but i can see that this is going to turn into another money suckin speed demon - WHOO HOOOOOO!
Old 10-14-2004, 08:54 AM   #17569
Sow&Steady's Avatar
It gets worse ... when you're the one ending up driving all the cars!
Old 10-14-2004, 08:55 AM   #17570
KevinS's Avatar
Yep, it will. Alot enough to be too much.
Or you can drill a 3mm hole in the stock rear shocktower and cut the tops off. Works for the 705, which probably has the same rear shocktower as the Impulse.
What a coincidence, money sucking speed demon is what I call my 705 too!
KevinS is offline   Reply With Quote
Old 10-14-2004, 08:57 AM   #17571
markp27's Avatar
Send a message via ICQ to markp27
I call mine the 1/8th killer although it is only a name in theory, as I haven't put it all together yet - but it'll be a long winter and I'll have lots of time
markp27 is offline   Reply With Quote
Old 10-14-2004, 09:00 AM   #17572
KevinS's Avatar
If you have time to drive more than 1 car... or even one car.
My 705 hasn't been run since late Oct 2003. Yet I keep spending money on it.
Old 10-14-2004, 09:02 AM   #17573
Sow&Steady's Avatar
When there's a will, there's a way.
Old 10-14-2004, 09:03 AM   #17574
the confessions of a true addict. (i hope there's room in that box for both of us).
Old 10-14-2004, 09:10 AM   #17575
markp27's Avatar
Both???? don't forget Sow and myself....we have been in there for a long time!
Old 10-14-2004, 09:18 AM   #17576
Sow&Steady's Avatar
Spoken like a true RC nut!
Old 10-14-2004, 09:31 AM   #17577
ha!
well this baby's all mine now!!!!
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5925908420
as flava-flav would say: "YEAAAA BOOYYEEEE"
Old 10-14-2004, 09:45 AM   #17578
Suspended
If it fits my 705, it should fit your Impulse too.
And it does fit on my 705.
i like that body...choco
SERPENTFREAK69 is offline   Reply With Quote
Old 10-14-2004, 11:03 AM   #17579
KevinS's Avatar
Thanks!
The orange on the body is actually fluorescent orange, which is just a bit lighter than the GQ rims, but every picture I take, it comes out like this. Almost red. The GQ rims don't look like they should either. Same on 710 pic below.
Anyone with good photographic skills know theres anything I can do about it? I have an Olympus C-725 UZ...
Old 10-14-2004, 12:14 PM   #17580
Suspended
Thanks!
whatever color,it still looks good!!choco
