Serpent 710
Originally posted by sn4il
I dont think it was me, I read all the articles and whatever i can find on the net.
I think my servos are fine, i set everything up according to this FAQ
I just worry about clutch and gearbox. But i think i would have to play with this at the track.
Thnx
Max
Thnx
Max
Its very good.
Originally posted by Bxclip
i said my front shaft wasn ton correctly is that why my car was spinngout when i was brakin
As to your question:- what do you mean your front shaft? The dogbones? Is it both not correctly on or just one? Which one?
In general though, what MarkP says is correct. If your car spins when you brake, it is most likely because you're using a one-way and your brakes are set too strongly. The rear tyres locks up upon braking, the front tyres have no brakes and continutes turning, your car spins out.
Hello, first time posting,
I had a kO on off switch go bad ,burn't up two throttle servos,I had this switch for two years first on a 705 no problem installed on the 710 next to last race notice battries would not last 5 miniutes ,must be a bad cell right, wrong check voltage with multimeter all cells are fine but with kO switch the voltage was way off killing two servos has anyone had this problem before? thanks for your help.
thsi car is sick i drove it with front shaft locked adn so when i press full throttle the cars back wouldnt spin i didnt have brakes i forgot to screw the top to the lever and at full speed i was turnin on my street good.i didnt hti the park cars so that showed em the sick handling thsi car has. tomorrow i will driv ewith fornt shaft lcoek dand brakes workin hopefully the brakes are good goo serpent now i dotn regret spend all this money over 1000 a G on this car it satisfied me
Originally posted by kreidel
htat osunds rgeta tiis anawsmoe cra and ithikn hte caris rgeat toilovemycaritisthebestever
"tfel ot thgir gnitirw eb ll'eh wonk uoy gniht txeN"
He should slow down and type correctly. I think it is rude to ask for help and then we have to decode what he wrote. He flip flops the letters in the words and does not uses spaces. It looks as if he spells fine, just needs to slow down typing and then proof read before he submits his post.
Originally posted by Sow&Steady
Glad that you're happy with the car!
Originally posted by rwisejr
I'm glad he is happy too. I will be glad when he fixes that keyboard issue.. I think part of his problem is that he is using a wireless keyboard that is defective and he is also typing faster than it responds.
