Serpent 710
Originally posted by Sow&Steady
A 5-port JP-FX should do the trick ... waddaya think?
The short wheel base mod I did is amazing. Well worth doing for foams.
Well, that goes to show a lot that it's not the car... It's the driver most of the time.
First comment: please use full stops in your sentences at least ... I had to read your post a few times to understand it.
Second, you need a pair of specs or microscope.
(j/k)
Originally posted by InitialD
Why are we not surprised?
Cool. I know a racing buddy of mine is using that on the 705 and is almost consistantly getting into the top mains in most races.
Originally posted by Bxclip
i have a problem with the differential. i put the bearing sin and when i go to put the other side it the ball bearings stops it form getting close enoguh to hold the balls it. i think its step 3.0
Originally posted by bigcountry
I just got a 710. I'm looking for suggestion on what type of good motor I should go with.
JP FX engines and NovaMax engines are very fast but they are also expensive.
Originally posted by nitro rookie
I looked on 3hobby already and will be doing most of those mods as I put the car together.
It's good to know how the car handles stock (which is great BTW) and then make changes as and when necessary.
Originally posted by crashed_1
So have you run it enough that it now needs a new P/S change? Jeez, I haven't even seen your JP in action !
Perhaps it's for the better. See no evil and you'll not get tempted !
Any plans to go this weekend?...
