Serpent 710
Old 07-16-2004 | 04:48 AM
  #13966
KevinS's Avatar
Default Re: Re: Re: Re: Re: Titanium screws
Originally posted by markp27
Very interesting - vee must have a look at ziss
Shouldn't that say: "Vaary eeenteresteenk"?
KevinS is offline
Old 07-16-2004 | 04:55 AM
  #13967
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Titanium screws
When it's German with a Dutch Akzent
markp27 is offline
Old 07-16-2004 | 05:36 AM
  #13968
KevinS's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Titanium screws
That was my attempt of English with a mad-German-scientist accent.
KevinS is offline
Old 07-16-2004 | 06:27 AM
  #13969
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Titanium screws
An exzellant attempt mein junge Freund non-ze-less
markp27 is offline
Old 07-16-2004 | 09:09 AM
  #13970
Default Switch to 710
Thanks for all the info. Look like the 710 is a very durable car.
Well, I'm from Sabah, MY.
I've been running NTC3 for a year and feel that the running cost is quite high, some key component parts like wheel bearing, diff gear and pinnion, flywheel, CVD ect is not durable. But I have to said it is very easy to handle.
alan is offline
Old 07-16-2004 | 09:24 AM
  #13971
KevinS's Avatar
Default Re: Re: Titanium screws
Originally posted by InitialD
Mine are all from the Barracuda electric car maker Xenon / Alex Racing.
Are those hex, not philips?
Do they come in packs of 8 or 10?
Are they available in most lengths as used on the 710?
Are they available with different heads? (socket, button, flat)
Do they have M4 too?
If the answer to all above questions is yes:
Where do I get those?
I have specific requirements. I don't need a set thats 90% or even 100% the same as for the 710 since I use a lot of aluminum screws too.
KevinS is offline
Old 07-16-2004 | 03:17 PM
  #13972
wolfejohne's Avatar
Default Re: Re: Addition to the family!
Originally posted by Pyramid
Does not look like a GLASS car to me
PS: Please read last posts in case you dont get my jokes
I used up a hole box of BAND-AID's building the car, can't wait to run the thing.
wolfejohne is offline
Old 07-16-2004 | 04:04 PM
  #13973
Default Track width
Hi guys I have been looking for an explanation of Track Width i would just like to know how this works? For example I recently ran a smaller track width at the rear which seems to give me less steering, why is this?
Thanks for your help
Brett.w is offline
Old 07-16-2004 | 04:06 PM
  #13974
Sow&Steady's Avatar
Default Re: Re: Re: Re: Titanium screws
Originally posted by Sparky66
SOW its not my site but they are where I live - Sydney , Australia.
I emailed them with a uestion but no responses so far!
I don't think they've got the hang of this on-line thing yet ... besides you're probably a good "live" customer.
Sow&Steady is offline
Old 07-16-2004 | 04:07 PM
  #13975
Sow&Steady's Avatar
It rains so much here at the moment, that I can't even get outside - no rust problems
Old 07-16-2004 | 04:17 PM
  #13976
Sow&Steady's Avatar
Default Re: Track width
Think of it as your stance. With your feet together you're pretty wobbly, easily push to one side or another, in other words your weight shifts easier. On the contrary, if you spread your stance you are more stable in terms of side to side weight shift ... a lot harder for someone to push you to one side or the other.
Similarly, if your trackwidth is narrow, the weight of the car can shift more/easier from side to side. Conversely for wider track width.
Within limits and depending on your overall set-up ... narrower trackwidth in the front gives a little more steering because the when you initiate a corner you're starting to force the weight of the car to shift from side to side.
  #13977
Sow&Steady's Avatar
Default Re: Re: Track width
Originally posted by Sow&Steady
Think of it as your stance. With your feet together you're pretty wobbly, easily pushed to one side or another, in other words your weight shifts easier. On the contrary, if you spread your stance you are more stable in terms of side to side weight shift ... a lot harder for someone to push you to one side or the other.
Old 07-16-2004 | 04:51 PM
  #13978
Thanks for the great explantion
Brett.w is offline
Old 07-16-2004 | 06:02 PM
  #13979
cyba888's Avatar
Default Re: Re: Re: Addition to the family!
cyba888 is offline
Old 07-16-2004 | 09:43 PM
  #13980
Pyramid's Avatar
Registered User
Originally posted by PSI Racing
What?
East..
Pyramid is offline
