Serpent 710
Old 07-15-2004 | 06:12 AM
  #13936
Originally posted by BIBOY
i agree initial D my car has almost all the hop ups by 3racing and still alot lighter than any mtx 3 or evo rr....
I also have installed all the 3Racing Hopups .(hopups cost more than complete car kit !) My car weighs in at 1.736 kg without body or fuel ! My car is fitted with the titanium pivot balls not the aluminium ones and replaced all screws on car with stainless steel ones ( from RCSCREWZ ).
http://www.rcscrewz.com/1_10_nitro.htm
All the replaced parts in aluminium have increased the weight substantially .
Is my 710 heavy ???
Sparky66 is offline
Old 07-15-2004 | 06:14 AM
  #13937
Marcos.J's Avatar
Super Moderator
Default Re: Re: Re: Re: Re: Re: Re: Re: Bling, bling
Originally posted by 2Lmon
Thanks Marcos...awesome track. Wish I could run my 710 there
me too
Marcos.J is offline
Old 07-15-2004 | 06:47 AM
  #13938
Sow&Steady's Avatar
Default Re: Addition to the family!
Originally posted by wolfejohne
I finally finished my first Gas Car!
I would like to say thanks to all who have helped me with questions and problems.
That 710-3PK combo looks good ... just like my combo!
Sow&Steady is offline
Old 07-15-2004 | 06:59 AM
  #13939
Default Titanium screws
Hi,
Does anyone use titanium screws in his Serpent 710?
Where did you find them?
I want to try titanium screws in my Serpent 710. Not because of the weight saving, but more for the strenght.
I thank you in advantage.
840918001 is offline
Old 07-15-2004 | 07:08 AM
  #13940
markp27's Avatar
Default Re: Titanium screws
Originally posted by 840918001
Hi,
I'm not sure that the strength will be any better than the standard one - the are after all screwed into plastic parts.
I do have titanium screws, though - mine are all tamiya screws - just find a dealer who supplies good tamiya rc cars and he'll be able to order the screws for you.
Cheers, Mark.
markp27 is offline
Old 07-15-2004 | 07:16 AM
  #13941
Default Re titanium screw
Thanks Mark,
The tamiya screws, are these good?
Old 07-15-2004 | 07:21 AM
  #13942
Sow&Steady's Avatar
Hi,
Mine are all from Speedmind ... they used to have a package ready for the MTX3 which are 90% similar to the 710 ones.
Old 07-15-2004 | 07:25 AM
  #13943
Hi,
Try http://www.racefactoryrcp.com/
Sparky66 is offline
Old 07-15-2004 | 07:31 AM
  #13944
Sow&Steady's Avatar
Default Re: Re: Titanium screws
Sparky, is this your site or have you ordered from them? Where are they located?
Old 07-15-2004 | 07:39 AM
  #13945
PSI Racing's Avatar
Default Re: Re: Re: Titanium screws
I like that Stratus body they have on there.
It's from a company called East.
Has anyone heard of them?
PSI Racing is offline
Old 07-15-2004 | 07:55 AM
  #13946
SOW its not my site but they are where I live - Sydney , Australia.
Sparky66 is offline
Old 07-15-2004 | 08:14 AM
  #13947
TitaniumR's Avatar
Hi,
Ti screws will not be as strong as stock for sure. You can tell as they can be cut easily using a plier. But you'll have a very hard time trying to cut or bend the stock steel screws. The advantage is in weight over stock and stronger but heavier than alu ones. I also noted that stock serpent screws tend to rust....
TitaniumR is offline
Old 07-15-2004 | 08:32 AM
  #13948
KevinS's Avatar
Most RC manufacturers use lower grades of Ti, which is a shame. Higher grade (5 and up ) Ti is just as strong as steel.
About stock Serpent screws; lately some are of poor quality. Especially 4mm grub screws and some 3 and 4mm button head screws don't fit my Hudy allen tools...
(yes, I used the correct size )
KevinS is offline
Old 07-15-2004 | 08:35 AM
  #13949
cyba888's Avatar
I use Duralube on my screws and the rust just falls off, it also keeps it from rusting. I was too lazy to take the car apart so I just put some on a Q-tip and smear it on the top of the screws or where I can reach them at. NO more rust for me
cyba888 is offline
Old 07-15-2004 | 08:45 AM
  #13950
markp27's Avatar
It rains so much here at the moment, that I can't even get outside - no rust problems
markp27 is offline
