Serpent 710
Originally posted by markp27
HAH! I knew I saw that hooded Obi-Wan figure at my track the other week
Originally posted by Sow&Steady
My friend ... I think you've got height giddiness after that Alpen race ... you sure its you head that is not OK instead of your other end? You're beginning to see things ... that was D, not me!
As for my head, I know it isn't alright, I mean, what kind of an idiot would pay good money to torture himself for 12 hours in the Alps!
Aaahhh you mean I mixed up the Jedi Mind trick with the Ring trick
Going kayaking ( spelled right I hope ) for 25 miles on the North sea seems to be fun also
Just don't like the watertemp in September though
Originally posted by bigcountry
I just got a 710. I'm looking for suggestion on what type of good motor I should go with.
BC
BC
if there is no rules, get whatever powerful you can
personally recommand Novamax .15 7port for out law if you can drive it
Originally posted by nitro rookie
I just ordered my 710 yesturday. I was just wondering if there are any upgrades that I need to get before I get it and put it together. I was also reading in earlier post that the steering servos are a little problem. Any suggestions on what servos fit and work better than others would be great.
As for steering servos, I've got Futaba 9550 in one car and Sanwa WRX in the other without problems. I've also used KO 2343 in the past no problems.
Anything else you want to know you should download the 710 FAQ assembled by Glenn Cauley and MarkP. download from 3hobby.com or just directly from MarkP's signature here.
Originally posted by Car Breaker
it depends on what type of race you want
Originally posted by impalabob64
hey i did,nt use the picco carb ,i used a novarossi carb my temp,was around 235.I use the nova carb because i had a picco before there carbs where abit touchy in tuning.
Sow&Steady
Thanks for the reply. I looked on 3hobby already and will be doing most of those mods as I put the car together. I am looking to buy another engine too. I don't want to tear my NTC3 apart yet. I will continue racing that until I get the 710 the way I want it.
Anyone else with ideas please send them my way, I'm looking forward to any help I can get.
