Serpent 710
Old 08-07-2004 | 09:38 AM
  #14551
markp27's Avatar
Originally posted by brian6989
Can someone please help im new to the 710 (switched fromNTC3)and the stock set-up with (37 foams) didnt seem to work very well on my track(very loose) . Can someone thats tryed a set-up off mytsn.com give me a good one to start with. The tracks we usually run on are medium traction, medium size, fairly open. I have a Hudy set-up system. Thanks for the info
Brian
Depending on where you are, 37s may be too soft - could be they overheat and you loose grip. Even in coolish conditions, I've been running 40s.
A silly question: have you checked carefully that you car is setup correctly - usally the stock setup works really well and only needs to be tweaked to get it to work for different tracks, due to the wide sweet spot of the 710.
Check your diff isn't too tight and stuff like track width, toe in, camber, anti-roll bars, etc. are definately setup as per standard setup.
It would be better to invest your time trying to get a setup which works for you by starting from the standard setup and then using the "setup-book" to get it to work for you, as you'll also get to know the car better
Cheers, Mark.
markp27 is offline
Old 08-07-2004 | 09:56 AM
  #14552
That could be im a off road racer in the past and am new to the onroad racing ran a ntc3 2 races and figured out it wasnt what I wanted. I understand ride height and caster/camber and toe but still a little unsure if im setting the upstops and down stops correctly. Our temps this time of year are about 80-90 degrees
brian6989 is offline
Old 08-07-2004 | 10:01 AM
  #14553
also in measureing the width of the car is it 200mm with the tires on? or off I bought a hudy set up system and in the instructions in up and down stops are a little unclear? any help is very much apprecitated
thanks Brian
Old 08-07-2004 | 10:11 AM
  #14554
markp27's Avatar
thanks Brian
Don't use upstops, remove the screws for them altogether. For the downstops, support the chassis on the Hudy blocks and remove the shocks and sway bars. Then use the hudy droop measuring too to ensure that they are set correctly. The droop has to be set very carefully as it has abig effect on the handling. Just follow the instruction in the setup book.
For track width, meausre it with the wheels on and with the car on the ground. Simply put a ruler across the width - also check to see if left and right sides are equal.
markp27 is offline
Old 08-07-2004 | 10:13 AM
  #14555
markp27's Avatar
Hmm sound a bit too warm for 37s.
markp27 is offline
Old 08-07-2004 | 10:30 AM
  #14556
Thank you markp27 for the info I will also try some 40 tires as well
Old 08-07-2004 | 11:35 AM
  #14557
markp27's Avatar
No problems - but check carefully the setup is done correctly first - it is worth the time investment. Once you've got the basic setup, then you can easily make the small adjustments to get to your desired setup. And you'll enjoy driving the car all the more
markp27 is offline
Old 08-07-2004 | 10:02 PM
  #14558
EdwardN's Avatar
Originally posted by markp27
Do you mean overreving without accelerating - if so, then it must be the clutch.
If it were overreving when he released the trigger at the end of the straight, then it would be the LSN being too lean.
Mark.
It is overeving when he hit the triger, right he release it to drop speed little bit. It happned only on the exit from straight , doesn't happened nowhere else.
EdwardN is offline
Old 08-08-2004 | 10:27 AM
  #14559
Your problem is the one way bearing in the 1. gear. Lube or replace it, and your problem will be gone.
Finken is offline
Old 08-08-2004 | 11:15 AM
  #14560
EdwardN's Avatar
Thanks a lot. It does make sence.
EdwardN is offline
Old 08-08-2004 | 03:14 PM
  #14561
n1technik's Avatar
hey guys, any idea on why my kit came with black flywheel and hudy spring steel colored pinion?
and it didn't come with a spacer for the pinions.
i do remember the flywheel being "serpent flywheel color" when i built 710 last year. anyways any info would be appreciated.
n1technik is offline
Old 08-08-2004 | 03:16 PM
  #14562
n1technik's Avatar
ah and here's my new delta car with Ralph's body on now i'm kicking myself for not getting it signed
Old 08-08-2004 | 03:33 PM
  #14563
KevinS's Avatar
Looks like you have a kit from a new batch. The brown pinion replaces the black pinion for which you needed the spacer. Never seen that black flywheel though...
Got a thicker rear shocktower, thicker bumber plate and longer rear lower arms too?
KevinS is offline
Old 08-08-2004 | 03:34 PM
  #14564
KevinS's Avatar
Nice body...
Serpent BeNeLux sold old team 705's a while back but I didn't get one... Could be worth something in the future!
KevinS is offline
Old 08-09-2004 | 06:21 AM
  #14565
Neil Rabara's Avatar
Sweet. You should have had it signed.
Neil Rabara is offline
