Serpent 710
Originally posted by Sow&Steady
The 5.8 mm ones must have either come from my 705 kit or the older 710 kit. I also have silver balls joints which are also 5.8mm ... don't know where they came from though.
Originally posted by stankulas
i am having a problem with my car it seems to kick out the rear or oversteer mid corner when i go around the turn and stuff the triger i am not sure if it is my driving or the car it does it when making left or rights and the car fells balanced or not tweeked if anyone can give any advise it would be apprecated. traction is low and the track is small and tech.
Else, I would use less front camber (-0.5 to -1) and more rear camber (-3 to -4).
Originally posted by rcjayy
Guy's I have a serpent 710 or course and im running it with a ns12S5 and I can't keep the car straight for two feet, this car is all over the place and totally undriveable. could the engine be to powerful for the car? or is there some type of an adjustment that can be made, please assist, I want to race it before the summers out but im afraid that I might kill a spectator.
Originally posted by GoldFinger
Blip throttle when your car off ground. Watch the rear tire.
If it goes up and down... thats it!
Especially when you blip the throttle and the car is on the starter box. It is very obvious that the rear wheels jump on throttle input.
Originally posted by InitialD
If everywhere else works fine, then go for a harder front sway bar setting.
I mean, the sway bars are providing more of a correcting action and surely it is better to get to a better setup with the other components first.....or am I wrong?About the front camber - would you suggest a camber change to fix such problems when the fronts are wearing level?
Cheers, Mark.
Nah.... this thread came alive again.....
Bro, I didnt receive the PM.
Sorry bro. I'm in between work and still writing it.
Lots of stuff on the desk to clear after the break.
Originally posted by markp27
Getting some points from Wifey, so you can drive on the Weekend
In fact, this coming big race this weekend I could not make it. Preparation and practice would take too much time.
Q about the sway-bars: in the setup bible it is show as one of the first changes to make, but if you're starting from scratch (i.e. no setup for a track) surely it would be one of the last
Well for me, if I find the car good all around but except in the corners the car hooks up in the front and too much for my liking, I would just like to stiffen the sway bar up front. Sometimes, you just want very subtle changes because everything else is running right.
This is what I was meaning - if the car is working ok, then the sway bars are a valid change. But if I'm completely lost with my setup, I'll leave the sway bars until later when things start to come together.
I noted that on some tracks, -0.5 and -1.5 camber did not make soo much noticeable difference in the front tires. That of course to a certain extent, making it wear the same flat would be the correct way.
Not enough browny points yet !
Well my year of lack-of-driving continues - seriously injured myself just before my bike race last week
(still managed to get 63rd from 6500
), so I can hardly walk - on top of that I have a heavy cold and a GF who I need to take care of though some very difficult times
And wouldn't you just know it....the weather is perfect!
If you look at most of the setups posted on mytsn by the drivers, you'll notice that most of them only vary slightly from the stock setup !
Hope you're coping OK though...
GF has real problems though
her sister is in a very bad condition many miles away in Thailand
That's why you want an indoor track in your house !
cool!
why didn't I think of that earlier
