Serpent 710
Old 06-24-2004 | 03:11 AM
  #13021
Sow&Steady's Avatar
Originally posted by mop_iko
why you have to HOLD THE REAR DIFF to check?
are you sure that is the correct way to check your rear diff 'tighnest'?
mop
I think he was trying to check the functioning of the diff itself.
Mop ... I owe you some download posting for GeneRally ... haven't forgotten. Done any new tracks?
Sow&Steady is offline
Old 06-24-2004 | 05:36 AM
  #13022
Wap
Originally posted by Pyramid
Check/remove the diff collar (on L side)
thanks pyramid i will try that.
Punisher i am planning to attend that race. I probably will try and race phat boyz in two weeks are so, just to check out the surface.
Wap is offline
Old 06-24-2004 | 10:53 AM
  #13023
I am almost ready, building my 710, but i wonder, why isnt there a 5th bodypost in the kit??
How should i fix a 5th post on this car. Anyone have some pic`s of how it can be done?
And also, i have a Mazda 6 body, but when i try to fit it, the rear bodyposts, are coming out of the wing???
Finken is offline
Old 06-24-2004 | 12:15 PM
  #13024
Arno's Avatar
With the mazda 6 body the body posts go through the wing that's the way I have it , or you can put the body mounts on the other side of the shock tower.
Arno is offline
Old 06-24-2004 | 12:27 PM
  #13025
PSI Racing's Avatar
It didn't work.
I'll try again.
PSI Racing is offline
Old 06-24-2004 | 12:30 PM
  #13026
PSI Racing's Avatar
Second try.
Old 06-24-2004 | 12:48 PM
  #13027
Default Mazda Body mounting
Here's a pic. of mines
Key500 is offline
Old 06-24-2004 | 01:37 PM
  #13028
How did you get them to come out in front of wing??
Finken is offline
Old 06-24-2004 | 01:40 PM
  #13029
PSI Racing's Avatar
You need to mount the body post in front of the rear shock tower.
Old 06-24-2004 | 04:25 PM
  #13030
Sow&Steady's Avatar
Alternatively, you can read up on what I just did ... courtesy of Mark Green's mod ... I did the same but with a slight difference.
Go to 3Hobby.Com and read the article on the front page "710 Rebuild: One more mod ... "
Oh ... and another video in a couple of hours too.
Old 06-24-2004 | 07:00 PM
  #13031
wolfejohne's Avatar
Default Re: Re: Cluth bell Gear Spacer?
Originally posted by InitialD
Didn't you get this note in your kit?
I did not get the note or the spacer in all three kits.
I believe with the newer bronze coloured pinions (1st gear especially), you do not need them anymore.
The spacing between the pinions is smaller than the spacing of the two speed gears. The spacer might correct the problem. I have assembled the pinions on the light weight clutch bell and they run true without the spacer.
wolfejohne is offline
Old 06-24-2004 | 07:15 PM
  #13032
Pyramid's Avatar
Registered User
I wonder if you have the first prototipe batch The 5th is already there
Pyramid is offline
Old 06-24-2004 | 07:23 PM
  #13033
InitialD's Avatar
Default Re: Mazda Body mounting
I mounted mine the same. The rear body post on the rear shock tower is mounted the other side (towards the front). But I believe you need to pull and mount the shell more towards the rear. Some shaving of the front foam bumper is also required.
InitialD is offline
Old 06-24-2004 | 07:24 PM
  #13034
Pyramid's Avatar
Registered User
Default Re: Re: Re: Re: Re: Re: Helios
Originally posted by Sow&Steady
Right. Perhaps a gentle "reminder" from the Tx manufacturer that we ought to use "their" servos.
I spent 3 hours last night installing Helios on my S710. Results, I put my 3pk back on as it by very far more convinience and safer
Pyramid is offline
Old 06-24-2004 | 08:00 PM
  #13035
Default Re: Re: Re: Re: Re: Re: Re: Helios
Im asking to KO PROPO how to make the servo come "alive" without switching ON the TX first.
Here is the answer :
Arifin,
I would install a switch in-between you battery and receiver. It is safer to turn on your Tx first, then your Rx.
Sincerely,
Robert Morris
KO PROPO USA, Inc.
Is anybody ever see the Mr.Burch and Mr.Cyrul car?
Is there any "switch" in it ?
GoldFinger is offline
