Serpent 710
Originally posted by markp27
I liked Ray's comment: "Eyes on - eyes off"
Pretty much summed up what we saw
Great DVD!
Great DVD!
I can not imagine myself If I would be there , How many time I will knock in to it !!
Originally posted by GoldFinger
Even with the new chasis, I still have some 0.5-1mm kick up if front, strengthen front belt is making it worst.
After hard impact, usually the notch on the X bracket will broke.
And this will make chasis bend(upward) more.
But I have not had a hard impact since. The chasis seems to sag and bend on the rear side. Very gradual and the point originaltes from the center of the chassis near where the X bar is mounted on the chassis. But this is after some time of playing and racing. Perhaps it's due to the acceleration force and torque from the engine.
In 705, X braket is aluminium so the carbon stiffener is the one that will broke.
Originally posted by InitialD
[B]But I have not had a hard impact since. The chasis seems to sag and bend on the rear side. Very gradual and the point originaltes from the center of the chassis near where the X bar is mounted on the chassis. But this is after some time of playing and racing. Perhaps it's due to the acceleration force and torque from the engine.
Be carefull, you will make LHS having hard time to sell high torque engine..
I think I'd rather have a side stiffener break than have the chassis bend slightly. Side stiffeners at that angle and plane is very difficult to break unless very hard head on impact. Have you seen the aluminum X bar yet? I'll wait for that one too.
The X bracket is not out yet, maybe after Holland anvancing through Euro2004 Final.
Originally posted by Pyramid
Other brand will do the same thing D.. Loosen the top stabz holder screws, press the rear shock tower and re-tighten. That trick works only before you run the car again.. so I do not put much attention on it but I always pay attention on side by side flatness.
Im sure that my stock, the side stiffener will having birthday in the store. So many kits out but not one of them buying it.
I'm not sure how much I posted here before I went on Holiday, but the FX is wild!!!!
I was running at about 85C or 90C and it was faster than the 2106 tuned!!!! This thing is a monster
I've got it running at 100C just before I went on hols and will take it upto 110C when I get back to the track. Not sure what the max temp is on this - with it having ceramic bearings.
Crashed: you done any run-in yet? Have you got the cermic bearing version?
Cheers, Mark.
PS: I will also record the WAV file for you D - do you want a fly past or an idle?
Cheers, Mark.
Did you come across any problems trying to start it?...I'm really worried i might smoke my starter motors.
Anyways, everything is good to go as soon as i'm back from Joburg...time to kick some ass.
Originally posted by redsand
I've always wondered about it. Could the serpent starter box be the culprit ? Take a good look at the chassie when it is being pressed against the starter wheel, the middle part of the chassie slightly bends. This is due to the chassie being pushed down when using serpent type of starter box. Now, take a look at other boxes, like the mugen one, this type of box has a flat part where the chassie actually sits on it and when it is pressed the WHOLE part goes down.
Originally posted by crashed_1
I got the ceramic bearing version with blk coated shaft...but one thing i notice is the sleeves are tight as hell.Damn, i am having trouble cranking it with my hands even with the flywheel attached...
You shooting Julius' new plane in Jo' ?
I wondered the same thing too since I did not hit anything hard. The funny thing is the bend also starts from the rear end.
At the track I don't have power to heat up the engine with a hair-dryer, so I used my car's heater to get the engine warm before starting it - then it was ok.
The guys at the track must be wondering why you carry the 710 into the car.
