Old 06-23-2004, 08:23 PM   #13006
Default Re: Re: Re: Re: Re: Re: Re: Re: Helios
Originally posted by daniz24
So, am I qualified enough to be your wingman... huh? Iceman?
Ya.. ya ya .. there is nothing I can say for now..
Please give me some more racing hour, one day you will be proud if you can pit me
GoldFinger is offline   Reply With Quote
Old 06-23-2004, 08:36 PM   #13007
Wap
hey guys i notice a problem w/ my rear diff.
when i hold the rear diff and spin the right rear tire the left rear tire does not move.
when I hold the rear diff and i cannot spin the left rear tire at all.
what is the Problem? Please help
Wap is offline   Reply With Quote
Old 06-23-2004, 08:41 PM   #13008
Wap
correction - hey guys i losen the the diff adjustment which allowed me to spin the left rear tire while holding the rear diff.
However the when i spin the right rear wheel the left rear wheel does not move.
Old 06-23-2004, 08:51 PM   #13009
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
too loose probably?
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 06-23-2004, 08:56 PM   #13010
Wap
jfc thanks for the response.
How can one side spin and the other does not? i will try to tighten the diff.
Old 06-23-2004, 09:11 PM   #13011
Pyramid's Avatar
Originally posted by Palmaris Europe
You want me to give away all my secrets
Otherwise there woulnd`t be a close competition.. not too much fun
Pyramid is offline   Reply With Quote
Old 06-23-2004, 09:16 PM   #13012
Pyramid's Avatar
Default Re: Re: Re: Re: Helios
Originally posted by Sow&Steady
Yes, its true. I still use the 2343 on my MTX and the 705. Don't why but they do that (with both, the HRS and the normal receiver too).
They only do that when using other brand of transmitter or the servo will behave the same even with HELIOS?
Old 06-23-2004, 09:19 PM   #13013
Wap
Punisher
where are u racing this weekened?
And however is in the DFW area where are u racing? I want to race my x-ray & 710.
let me know so we can have a good turnout.
wap
Old 06-23-2004, 09:21 PM   #13014
Pyramid's Avatar
Originally posted by cyba888
These are the specs for the S9550
SPECS: Speed: .14 Sec/60 Deg @ 4.8V or .11 sec/60 deg @ 6V
Torque: 67 oz/in @ 4.8V - 83 oz/in @ 6V
(4.8 kg/cm @ 4.8V - 6.0 kg/cm @ 6V)
Futaba S9451
SPECS: Speed: .13 Sec/60 Degrees @4.8V - .10 Sec/60 Degrees @ 6V
Torque: 97 oz/in @ 4.8V - 121 oz/in @ 6V
(7.0 kg/cm @ 4.8V - 8.7 kg/cm @ 6V)
It seems that the S9451 has 30% more torque. Do you think it will make a big difference if I were to use it for drag brake? I was just hoping that if I were to get the S9451 and use it for drag brake then it shouldnt put as much stress on the servo compared to the S9550? What do you guys think....
If only torque that you concern about for your drag brake.. do experiment this way.. find a metal/steel with 5kg in weight and put it on top of your spring. Does the spring being push till the end? I guess with about 0.5kg steel they already did
Old 06-23-2004, 09:23 PM   #13015
Pyramid's Avatar
Check/remove the diff collar (on L side)
Old 06-23-2004, 09:28 PM   #13016
Pyramid's Avatar
Hmmm... Mr. Giant likes to read... In case you are ready to let go TM, how about Serpent-ID sponsored driver? I`m sure you already know a lot about this car
Old 06-23-2004, 09:53 PM   #13017
cyba888's Avatar
Sounds too complicated I think to be on the safer side I will get the S9451. The size and weight wont make that much of a difference to me.
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 06-23-2004, 10:56 PM   #13018
Trader Rating: 2 (75%+)
Punisher
wap
Hey Wap,
I'll be racing at my hometown track in Austin HobbyTown's Race Track.
I've been racing at Phat Boyz race track the past coulpe of weekends and be racing at my local track for a while until Phat Boyz holds the Texas Touring Car Shootout. Hope you can make that race!!
PUNISHER is offline   Reply With Quote
Old 06-24-2004, 12:27 AM   #13019
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
why you have to HOLD THE REAR DIFF to check?
are you sure that is the correct way to check your rear diff 'tighnest'?
mop
mop_iko is offline   Reply With Quote
Old 06-24-2004, 04:09 AM   #13020
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Helios
Right. Perhaps a gentle "reminder" from the Tx manufacturer that we ought to use "their" servos.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
