Old 09-24-2004, 09:27 AM   #16201
markp27's Avatar
Send a message via ICQ to markp27
Originally posted by SERPENTFREAK69
will my rb concepts v12 fit these monoblock?i hope choco
If it fits the standard serpent blocks, then yes.
markp27 is offline   Reply With Quote
Old 09-24-2004, 09:27 AM   #16202
Send a message via AIM to Bxclip
turn my 710 with x12 on first first time with rubo II pipe in one try yeaaa btu hne i pull brakes the car spins to the left and does a 180 what do i do to fix that? what can be wrong?
s733/ flash 12 3 tuned Maxy Modified/ nova 2660 w/ medium manifold/ spektrum dx3
Bxclip is offline   Reply With Quote
Old 09-24-2004, 09:35 AM   #16203
markp27's Avatar
You are running a one-way, I take it?
One of the main reasons is having you brakes set too hard. You can set your TX unit to reduce the amount of servo travel when you hit the brakes. You'll have to read your TX manual to see how you set this up.
Make sure you have accurately setup the car - this is vital to good performance! Don't set something without measuring it very accurately - it simply doesn't work - this is a racing car.
Read the tweak section in the FAQ - it answers questions like "why does my car spin out" - everything is covered there.
Cheers, Mark.
Old 09-24-2004, 09:37 AM   #16204
Suspended
OK THANKS ...I ASKED SERPENT,THEY TOLD ME THAT ANY ROSSI BASED ENGINE WILL FIT...IS RB A ROSSI BASED ENGINE?
SERPENTFREAK69 is offline   Reply With Quote
Old 09-24-2004, 09:43 AM   #16205
sn4il's Avatar
Thank You Mark for great help. I really appreciate it.
Anything else?
Last question. I promise
Is it a good idea to break-in engine on a starter box?
Max
sn4il is offline   Reply With Quote
Old 09-24-2004, 09:44 AM   #16206
Cheers, Mark.
shoudl i lock the one way my radio didnt coem with tx manual
Old 09-24-2004, 09:48 AM   #16207
markp27's Avatar
You'll stiil need to setup you TX for your servos otherwise they won't be properly centred and will have too much travel. You have to set these items up for both the steering servo and throttle servo.
If you don't do this, at best you'll end up burning out your servo - at worst your car will take off at uncontrollable speed and you won't be able to brake. You can't do half a job with these cars - they require a lot of time to be setup up correctly - failure to do so will lead to frustration and a big heap of broken parts.
I would also recommend locking your one-way if you have never driven one before.
Cheers, Mark.
Old 09-24-2004, 09:51 AM   #16208
never drove one i cant fidn my et uop book anythin online that ican read the set up? hwo do i set up the tx what is tx?
Old 09-24-2004, 10:13 AM   #16209
markp27's Avatar
The TX is your controller (transmitter). You'll have to look at the manufacturer's website to see if anything is available or go to your local dealer.
Old 09-24-2004, 11:01 AM   #16210
Default Re: Re first ride
Hi Sn4il,
The first 2 or 3 tanks your engine is runnig can be done on the starterbox.
The other 7 tanks there need to be more resistance.
Run in is best done by 10-12 tanks.
If you don't want to run in on track then use a run in bench.
Thomas
840918001 is offline   Reply With Quote
Old 09-24-2004, 12:04 PM   #16211
my frotn shaft wa sopn corrctly is that why ist was spiinin? i saw that it wasnt on correctly when i put thelock in
Old 09-24-2004, 12:34 PM   #16212
Send a message via AIM to kreidel
I think your keyboard on your computer is broken.
kreidel is offline   Reply With Quote
Old 09-24-2004, 03:53 PM   #16213
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
woah...your keyboard is totally broken. or maybe your sleepy???
doki_doki is offline   Reply With Quote
Old 09-24-2004, 04:06 PM   #16214
rwisejr's Avatar
Send a message via AIM to rwisejr
Post
Yes its is I already told him to change it because it gives me a damn headache trying to figure out what he is trying to explain.
rwisejr is offline   Reply With Quote
Old 09-24-2004, 04:45 PM   #16215
i said my front shaft wasn ton correctly is that why my car was spinngout when i was brakin
