Serpent 710
#3916
Originally posted by Picard
S&S
Thanks for the reply, i will try the locked front oneway, as well as the normal oneway, there are only 2 points on the track where I require brakes so the locked oneway will probably benifit me i hope
S&S
Just make sure at which point you should let the throttle off.
Then compare your laptimes after using solid fr axle.
#3917
Originally posted by InitialD
Whose wifey?
Like somebody mentioned, as long as wifey does not see more than 2 or 3 engines at one time, then you're pretty safe !
Whose wifey?
#3918
Picard, if there are reasonably sharp hairpins after long straights and almost none or little fast sweepers, the solid front axle is nice. If there are high speed sweeper, I find that the front solid axle drags the speed of the car and makes it slower and unstable. My 2 cents.
For small technical tracks where you need to slow down and turn in, the solid front would be excellent.
Thanks for your opinion as I am new at this
Unfortunately my track is a bit of both, fast sweepers and tight hairpins. 2 sweepers and 2 hairpins which require braking. Looks like I will have to test and come to a compromise, should be getting the kit tomorrow, any problems or anything I should know about when building the kit or is everything straight forwardThanks for your help
#3919
Originally posted by GoldFinger
Before locked your 1way, try to lower the front tire shore 1 step down from the rear and slam your car on to that hairpin without braking.
#3920
Hi ID
Hi ID
I've been using a one-way on a carpet track with my EVO III and I really like it now, so maybe once I can get back onto the outdoor track I will try the one-way once more.
#3921
Originally posted by markp27
Sounds similar to my track - really is a toss up between the one-way and the solid. I went for the solid and will remain there until my driving improves - the one-way was too much at first, due to the breaking areas.
I have been driving with a oneway at my track for 4 months now and dont have any problems, i feel very confident with a oneway but that was on an R12, so I am not to sure how the serpent will react with one. I have never tried a solid front and was curious about it and didn't know what the difference was between the 2. No-one from my knowlage had used a front solid at my track before so I will be the first
#3922
Hi MarK
Hi MarK
The 710 won't give you any problems with a one-way if you have already gotten use to one with another car.
Cheers, Mark.
#3925
Anyway, what does using softer front tires do? More steering? Wouldn't that make the rear unstable?
#3927
Yes it's true like what Mark mentioned that you get more consistant lap times if you're on full time 4WD brakes but there is where we need to strive for perfection !
Anyway, welcome to the fold and enjoy building your 710 kit !
#3928
Well, for me I thought having lots of brakes was better but on the fast track, braking just means that you go slower. With the one way, you can really push in the fast sweepers. The car carries more speed.
