Old 02-05-2004, 12:36 AM   #3931
cyba888's Avatar
Mark,
How did you get your avatar pic so big? What settings do you use?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 02-05-2004, 12:36 AM   #3932
Picard's Avatar
Originally posted by InitialD
As far as I know, only Serpent has the optional solid axle in the front.
That's probably why
Picard is offline   Reply With Quote
Old 02-05-2004, 12:40 AM   #3933
markp27's Avatar
Send a message via ICQ to markp27
Originally posted by cyba888
Was at the race a week ago and most drivers that I saw did not or barely use brakes. Maybe it has to do with the track that we run on.
For me definately - I have two long flat-out sections which end in two very tight hairpins - breaking is required here.
At the indoor track where I drive my EVO III when we drive clockwise, then I never have to break - simply let the car roll through the corners and left off the throttle at the correct point. But when running anti-clockwise, then I have two places where I have to break.
For both configurations (for the EVO III) I use a one-way although most of the other guys prefer the ball-diff/solid axel for the configuration where breaking is required.
For me I think I'm still quicker using the one-way whatever the configuration of this track.
markp27 is offline   Reply With Quote
Old 02-05-2004, 12:41 AM   #3934
markp27's Avatar
Mark,
The max size o the avatar is 80x80 pixels. I simply cropped the image I wanted to these dimensions and uploaded it
Old 02-05-2004, 12:41 AM   #3935
Picard's Avatar
Well, for me I thought having lots of brakes was better but on the fast track, braking just means that you go slower. With the one way, you can really push in the fast sweepers. The car carries more speed.
Yes it's true like what Mark mentioned that you get more consistant lap times if you're on full time 4WD brakes but there is where we need to strive for perfection !
Anyway, welcome to the fold and enjoy building your 710 kit !
Thanks ID and everyone that responded, it good to have different points of veiw. Now I hope my kit arrive on time, i can't take the waiting
Old 02-05-2004, 12:43 AM   #3936
markp27's Avatar
I haven't even ordered mine yet I have to wait even longer
Old 02-05-2004, 12:43 AM   #3937
InitialD's Avatar
Yes, the track you run on is very nice and flowing !
Old 02-05-2004, 12:49 AM   #3938
Sow&Steady's Avatar
Originally posted by markp27
I panick sometimes though - out it blurts and suddenly I'm in big trouble!
Sow&Steady is offline   Reply With Quote
Old 02-05-2004, 12:53 AM   #3939
Sow&Steady's Avatar
Hi MarK
I have been driving with a oneway at my track for 4 months now and dont have any problems, i feel very confident with a oneway but that was on an R12, so I am not to sure how the serpent will react with one. I have never tried a solid front and was curious about it and didn't know what the difference was between the 2. No-one from my knowlage had used a front solid at my track before so I will be the first
One other thing, unlike the 705, the 710 loses its steering only marginally when I locked the 1-way. Again, depending on the track layout and available grip, you may find that you need to refer to the "bible" and get more steering afterwards.
For our upcoming race here it appears that I need to remove my front roll-bar as well as go to 4 holes up front just to get comfortable. May need to do more to be fast ... we'll see.
Old 02-05-2004, 12:55 AM   #3940
Sow&Steady's Avatar
It is great fun to drive a solid, as the breaking is unbelievable! You can therefore drive very aggresively, which most probaby won't translate to a good lap time. One the other hand the one-way promotes smooth consistant driving, which is rewarded by quicker lap times.
The 710 won't give you any problems with a one-way if you have already gotten use to one with another car.
Cheers, Mark.
Mark, agree with you.
The problem is sometimes I end up in a heat with some "L-plate" drivers and unpredictable manouvers often call for unexpected hard braking. That means rear-end swapping for me ...
Old 02-05-2004, 12:56 AM   #3941
cyba888's Avatar
Yep, no tight turns, very wide and nice But the rain here is not helping, its been raining for almost 3 weeks straight except that it only stopped for 2 days During those 2 days it stopped 1 of the days I was busy and the other day was race day Will rain again this weekend as well
Futaba 4PX
Old 02-05-2004, 12:57 AM   #3942
Sow&Steady's Avatar
Actually, Kawahara makes an Al. insert to change the MTX diff into a solid. You could even use it in the Evo with a small mod.
Shhhhh! Don't tell them knukerheads!
Old 02-05-2004, 12:58 AM   #3943
Sow&Steady's Avatar
I notice that on my local track which requires a fair bit of braking, I feel that I'm faster on the one way.
Anyway, what does using softer front tires do? More steering? Wouldn't that make the rear unstable?
I think Goldfinger is one of Kok Heng's "students".
Old 02-05-2004, 01:03 AM   #3944
sparksy's Avatar
Trader Rating: 14 (94%+)
The Yokomo also came with a solid front in their RTR kits.
We used to put silly putty in out front diffs on the HPI Racer and early V-one R's.
But once you learn to drive a oneway its hard to go back to anything else, unless the track realy needs a front diff/solid.
Nice flowing lines will always be quicker than screaming up to the corners and grabbing a handfull of brake.
sparksy is offline   Reply With Quote
Old 02-05-2004, 01:10 AM   #3945
InitialD's Avatar
I agree with you. I hardly noticed the lack of turn in. Just that as time went on, I noticed that off power was a little lacking. Perhaps lacking droop when I continued to use my 55 mm tires ! Talk about poor !
Ummm, before this, I only knew one or two guys that was using 4 holes in front with NOT ARB in the front !
